connecting the dimmer?
Old Apr 16, 2005 | 06:55 AM
Default connecting the dimmer?
how do i connect the aftermarket radio's dimmer wire to the car?
i've tired soldering it to the dimmer wire on the wire adapter that goes to the stock harness, but all the lights still come on during the day.
i only want this thing to turn on when my dash lights come on.
Old Apr 16, 2005 | 09:32 AM
b00gers's Avatar
b00gers
Are you familiar with hooking up indiglo gauges? I would put it to that same wire. On my car, I think it is a red/blk wire. You also can take out your gauges and test each wire with a probe to see which one is getting current only when the dash lights come on. h: If you do a search on how to wire up indiglo gauges, you will probably find that wire. I just leave that wire connected to nothing on my stereos. What does it actually do?
Old Apr 16, 2005 | 11:23 AM
on my radio right now the lights are completely on when the car is on. when you attach the dimmer wire, the lights only come on when your dash lights come on. (like when you turn on your headlights at night)
aslo, you can control the inensity of the radio's light to match the interior's.
Old Apr 16, 2005 | 11:48 AM
ihookitup4u's Avatar
ihookitup4u
on most newer radios u need to turn on the dimmer feature. if the orange/white from deck is hooked to the red/black to the car then u did it
