ma audio tv trouble
Old Aug 27, 2002 | 06:15 PM
slammed1's Avatar
slammed1
Default ma audio tv trouble
i just bought a ma audio 7 inch wide screen and am having trouble with the sound and the picture rolls over from time to time........does anyone know anything about these things?
Old Aug 30, 2002 | 08:14 PM
arch iceman's Avatar
arch iceman
Typically the sound from these units suck, no matter who makes them, its a small speaker in the back of the monitor about the same size as the speaker in your cellular phone.
There should be adjustments for the picture on the monitor depending on the model you have. Did it come with instructions? It could be on screen adjustable, what kind of video source are you using to the tv?
Old Sep 1, 2002 | 03:09 PM
slammed1's Avatar
slammed1
i am running a ps2 to the screen and im not getting a hiss through the tv itself but through the whole audio system
Old Sep 1, 2002 | 07:43 PM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
how are you "injecting" the sound into your audio system? an FM modulator (if so, thats probably the problem) or an input on an aftermarket deck?? If you are using RCA cables into an input on your deck, make sure to keep them away from the power inverter and all those power cables, they can cause noise in a low level audio signal.
Old Jun 16, 2003 | 08:10 AM
KVZ_Productions's Avatar
KVZ_Productions
also the screen bounces if your power level drop and gain. you you have any amp in your system that can be pulling power level down to cause the screen to bounce? other wise id say its your rca cables picking up noise from local power cables. keep em apart they dont play well with each other.
-krazymatt
D16Y8
2
Jun 24, 2002 10:01 PM
crxsiperf
CRX & Pre 92 Civic
2
Jun 20, 2002 04:57 PM
