help a noob;speakers wont fit
Old Mar 10, 2005 | 06:08 PM
fuzzydd's Avatar
fuzzydd
Default help a noob;speakers wont fit
i just bought a pair of alpine 170a's and im trying to cram them into my door but the speaker has 4 mounting tabs that stick out and get caught when i try to put it into the housing.. its not flush =\
im assuming the speaker housing should be identical for civics from the same generation.. how did everyone else do it?
Old Mar 10, 2005 | 07:39 PM
augy's Avatar
augy
Pics make helping easy.
Old Mar 10, 2005 | 10:37 PM
Bricks2k4civic's Avatar
Bricks2k4civic
I'm not exactly sure what you're talking about, but could you break or cut the tabs off and still mount the speakers? If you have basic tools, you can modify the door or the speaker to make them work better.
Old Mar 11, 2005 | 12:55 PM
nex-gensjdmteg's Avatar
nex-gensjdmteg
you might have to pop out the back side of the speaker housing if that is what you are talking about but you needc to post some pics
Old Mar 11, 2005 | 01:30 PM
VPUPPY's Avatar
VPUPPY
also, what year is your civic?
Old Mar 12, 2005 | 12:25 PM
fuzzydd's Avatar
fuzzydd
Default pics
heres pics
File Type: jpg
File Type: jpg
Old Mar 12, 2005 | 12:28 PM
fuzzydd's Avatar
fuzzydd
oops forgot about this one
the magnet on the alpine is about half inch wider diameter-wise
and its about 1 finger deeper
i have no idea where to start
1998 1.6el
File Type: jpg
Old Mar 12, 2005 | 03:06 PM
chimchim's Avatar
chimchim
WRX cuz Honda won't wagon
I have kenwoods with tabs that stick out like that. However, on the kenwoods, the tabs were indented so I could just bend the off.
For your case, get some big wire cutters or tin snips or file to cut/file those tabs down within the size the outer circumference of the speaker to make it fit. You won't harm anything.
Old Mar 13, 2005 | 07:22 AM
fuzzydd's Avatar
fuzzydd
thanks ill give it a try
did the magnet get in the way though for ur kenwoods? the thing is noticeably larger than the stock one so im not sure anymore if its the tabs that are getting caught or the magnet or both
Old Mar 14, 2005 | 10:24 PM
bxsnypa's Avatar
bxsnypa
STOCK EJ8 noob
are those s-type speakers, if they are they didnt fit in the stock position in my car as well. I have a 98 ex coupe. I said ****i it and drilled a hole into the panel and it worked really well no problems to this day.
