Installing Speakers in96 teg GS-R
Old Mar 1, 2005 | 11:06 AM
tlg's Avatar
tlg
Default Installing Speakers in96 teg GS-R
Hey guys I am new at this and have read about 1000 posts before I threw one up here. I bought new speakers to replace the stock ones in the car. I figured I would start with the back since this looked easier.
When I poped the plastic covering off though, it doesn't seem to me the 6 1/2" Speaker will fit thru the opening and over the plastic clip pieces.
Is my only option to take off the moulding all aroudn the sides to acces it?
Also, I bought new Kenwood componet system for front, where would you recomend mounting the x-overs and is this a job a semi-newbie could or should take one?
Thanks in advance
Tim
Old Mar 1, 2005 | 06:22 PM
xXkenXx's Avatar
xXkenXx
The DON'T fit thru the opening. The only way your going to get those speakers in is by taking off the panel. There's alot of bolts so start searching. also the speakers don't fit through the bracket so you will have to screw the bracket on top of the speaker. As for the X-overs, stweeters mounted mines under the carpet so people can step on the when they sit back there. I suggest using sum industrial velcro and mounting it ibehind the panel on the body. Also your going to have a little trouble putting 6 1/2 in the front. Every reference books says integra speakers are 6 1/2 but they just don't fit well. depending on how deep your speakers for the front are you might have trouble fitting them in. Also your going to have to make sum plywood brackets. I suggest just adding 5 1/4 speakers and getting a conversion bracket.
Old Mar 1, 2005 | 06:30 PM
xXkenXx's Avatar
xXkenXx
look behind your door panel...there is a black plastic box that i think is just perfect for crossovers. screw it in or velcro
Old Mar 2, 2005 | 04:25 AM
99IntegraGS's Avatar
99IntegraGS
Not true.
Once the interior panel is removed, the speakers mount to the bracket from the top.
Old Mar 2, 2005 | 07:25 PM
xXkenXx's Avatar
xXkenXx
aftermarket speakers are not specifically designed for certain vehicles. Fitment issues could occur like in my case. Just a little suggestion to help work around any issues that could occur
Old Mar 7, 2005 | 03:50 PM
tlg's Avatar
tlg
Default Thanks
Thanks for the suggestions
