conFUSEd
Old Feb 9, 2005 | 06:16 AM
eg_bert's Avatar
eg_bert
hoooorraayy Beer
Default conFUSEd
i need some guidance wiring up my current system. as of right now my sysytem is working but my wiring could use a little help. i was wondering if anyone new the proper size fuses i should be using. as of now im runnin a jl 300/4 and a jl 500/1 amp. im currnetly using a 4ga power and ground set up.
my question is what size fuse should i have at the battery terminal and once i get a fused dist. block, what size fuses should i have going into the amps. anyone with electrical knowlege help me out? thanx
Old Feb 9, 2005 | 09:12 AM
b00gers's Avatar
b00gers
Both the 300/4 and 500/1 have fuses built inside, 40a and 60a respectively. Because there is a decrease in wire size from the distro-block to the amps, you should fuse it again. If those two amps are the only things getting power from the 4ga line...then put a 100a fuse near the battery.
Old Feb 9, 2005 | 10:27 AM
rcurley55's Avatar
rcurley55
you should always fuse when you decrease wire size - this is to protect the wire between the block and the amplifiers....
Old Feb 9, 2005 | 11:24 AM
sherwood's Avatar
sherwood
I missed Sean
:werd: take it from an electrician
rather replace a 5 dollar fuse then have to rewire you're entire car
the fuse should be rated like 5-10 amps less than what the wire can take just for cautions sake
Old Feb 9, 2005 | 11:31 AM
sherwood's Avatar
sherwood
I missed Sean
Default .
File Type: bmp
Old Feb 9, 2005 | 08:59 PM
b00gers's Avatar
b00gers
Thanks for correcting me.
Old Feb 10, 2005 | 12:10 PM
orbit77's Avatar
orbit77
i believe you should have a fuses in your distro box unless your using a ground distro box.
