trunk light not working, gotta be something simple!!
Old Jan 31, 2005 | 05:05 PM
jermothedrunk's Avatar
jermothedrunk
Default trunk light not working, gotta be something simple!!
i have a 98 integra 4-door gsr and the trunk light does not work. i checked the fuses and they are fine. i took the little plastic thing that holds the light to be checked to see if the transistor or whatever was blown but it was fine also. of course i replaced the bulb and still no frikkin dice. the only thing left would be the wiring or something in the trunk latch is not triggering to turn it on. any help on how i would go about getting this light to work again!?!? thanks for anyones help!
jeremy
Old Jan 31, 2005 | 08:27 PM
kill_kill_kill's Avatar
kill_kill_kill
it's sarcastic dude
blown transsitor may look fine ,,,have a DMM? that would help narrow it down
Old Feb 1, 2005 | 01:34 PM
jermothedrunk
DMM? not too sure what that is. i tested the transistior on the plastic thing and it was fine. the light lit up when we put a different power source to it, but when i put it back in my car nothing happens.
Old Feb 1, 2005 | 03:05 PM
VPUPPY's Avatar
VPUPPY
try the switch that activates the light. my 98 ls trunk light does not kick on all the time cuz that switch sticks every so often.
Old Feb 1, 2005 | 05:09 PM
jermothedrunk
the switch is on the latch right??
Old Feb 2, 2005 | 12:13 PM
VPUPPY's Avatar
VPUPPY
i believe so.
Old Feb 3, 2005 | 08:47 PM
kill_kill_kill
it's sarcastic dude
DMM = voltage and current and continuity measuring tool, would tell you if the sockety got power, and whether the high or low side of it was dissconected from battery terminal.
hooking the bulb up to another power source basically gave you same info though, no votlage at source probably a blown fuse or ****ed up connection?
Old Feb 10, 2005 | 07:43 AM
TrashCan's Avatar
TrashCan
Try to find the negative wire, or have another wire that will touch the negative end of the bulb to ground and see if it works or not. If it does, the latch is not making contact with the chassic ground.
Old Feb 11, 2005 | 01:13 AM
Synthead's Avatar
Synthead
Eeehhhh, I hope you get it to work. It sucks to have to take apart your car for a small problem like this. Try jumping your button while your at it too. If you get to the other side of it, touch a coin to the terminals and see what happens. You most likely have ground though. The entire chassis of the car is ground, therefore referred to as the "common ground" (cause every part of your car uses the same ground).
