Factory alarm
Old Nov 1, 2004 | 11:20 AM
RitcheyRch's Avatar
RitcheyRch
Default Factory alarm
What is needed to add the factory alarm to a 1998 Civic LX?
Old Nov 1, 2004 | 03:55 PM
Hondaman's Avatar
Hondaman
Black Pearl
You need the factory radio, keyless entry remotes, and Honda part number 08E51-S01-101F
You can get the remotes and module from www.honda-accessories.com. Get the correct remotes for your year car and get the module from a 99-00 civic EX.
Module---> http://www.handa-accessories.com/civelec00.html
Remotes ------> http://www.handa-accessories.com/civic98.html
I just installed this in my 96 civic LX about three weeks ago.
Old Nov 1, 2004 | 06:08 PM
RitcheyRch's Avatar
RitcheyRch
Thanks for the info. The aftermarket alarm that was already installed in my Civic was not properly installed and I had planned on completely removing it and installing factory keyless entry. However, after trying to remove the alarm and seeing how bad the wiring was I decided to take the car to another alarm installer and have them replace the alarm with a better unit and correct the wiring nightmare.
Old Nov 7, 2004 | 04:09 PM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
yeah, the factory keyless isn't an alarm. It just gets you in and out of the car....
if you want theft deterent, stick with an alarm.
I personally use both, depending where I park
Old Nov 7, 2004 | 08:51 PM
Hondaman's Avatar
Hondaman
Black Pearl
You can add a factory alarm to the keyless entry system. With the module I listed above, it includes a starter cutoff relay and links the keyless to the OEM alarm module.
Old Nov 7, 2004 | 10:22 PM
19.3secS2K's Avatar
19.3secS2K
still, no motion sensor h: only when the doors open....
thats not good enough
Old Nov 11, 2004 | 04:01 AM
RitcheyRch's Avatar
RitcheyRch
Thanks. I ended up getting another alarm installed in the car.
Old Nov 11, 2004 | 07:43 AM
19.3secS2K's Avatar
19.3secS2K
:goodjob:
