FARAD CAPACITOR Install
Old Jul 7, 2004 | 12:21 PM
93DelSolSi's Avatar
93DelSolSi
Default FARAD CAPACITOR Install
can someone show me how you install a FARAD CAPACITOR
Old Jul 7, 2004 | 03:07 PM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
its very simple... you'll need short pieces of wire (same gauge as power and ground for the amp) and some connectors. Pop out the power fuse at the battery. Mount the cap as close to the amp as possible to make the cable runs as short as possible. The power lead from the battery will go to the positive of the cap (instead of the amp). Then run a cable, as short as possible, from the same positive terminal to the positive connection on the amp. Then just a short ground wire (again, same gauge as the amp uses) and ground it to the same point on the car your amp is grounded to, NOT to the terminal on the amp.
BEFORE installing the fuse at the battery..... use a small test light or some other small light, connect each wire of the light to each one of the terminals of the fuse holder... the light will light up and gradually dim to nothing. Wait till the light goes out and then install the fuse. This "charges" the cap, if you dont do this you'll get a big spark when you install the fuse.
Old Jul 7, 2004 | 04:02 PM
b00gers's Avatar
b00gers
^^^ :werd:
heres a visual. note that the ground for the cap is not using the same grounding point as the amp. in my experience, either way is fine.
File Type: jpg
Old Jul 8, 2004 | 11:39 AM
Nelson's Avatar
Nelson
Administrator
Originally Posted by WiLL
^^^ :werd:
:thumbup: WiLL to the rescue!
That is pretty much the basic diagram to follow, if you have two amps, then it would be better to get a dist block after the cap, but not needed.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Jul 8, 2004 | 04:47 PM
b00gers's Avatar
b00gers
that should only apply if the two amps are both powering subs. since a farad cap is "designed" to give the amp extra juice when the bass hits.
Old Jul 15, 2004 | 07:16 AM
SiClone's Avatar
SiClone
X-Moder8er
nice drauwrring Simon.....
Old Jul 15, 2004 | 03:16 PM
ewilli's Avatar
ewilli
can i run the ground for the cap into a dist block with the ground with the amp and then to a ground on the car? all grounds being the same, wont this work?
Old Jul 15, 2004 | 05:26 PM
b00gers's Avatar
b00gers
CAN you do it? course.
just try to keep the ground wire as short as possible. hopefully no more than 18".
