System Setup
Old Aug 6, 2002 | 11:39 AM
Paulll's Avatar
Paulll
Hail Bent
Default System Setup
So i got my 350 Watts 4-ohm Amp and my Subwoofer. I have had them for a long time and i thought that i need to hook them up. If someone has the Time, could u give me simple step by step instructions on how to do this. Its a mono amp and one 12 in Boxed Cerwin Vega Subwoofer.
Thanks so much
Old Aug 6, 2002 | 12:06 PM
b00gers's Avatar
b00gers
list the model number and specs for both.
Old Aug 6, 2002 | 04:39 PM
Paulll's Avatar
Paulll
Hail Bent
Cerwin-Vega 12" Subwoofer VEGA-12D4:
Brand Cerwin-Vega
Frequency Response 20Hz-500Hz
Impedance Rating 4 ohms
Recommended RMS Power Range 600
Sensitivity 92 dB
Type Subwoofers
Woofer/Driver Size 12 inches
It is In A Q-Logic 12" Box, that is where it will Stay.
Bazooka EL1500 Amp:
500W x 1 Power Amplifier EL1500.
Bass Boost No
Number of Channels 1
Speaker Level Inputs No
Type Mono Subwoofer
I Don't have Any Wires yet, I know that I'm going to need them. Also, I have heard that you can Pick up an Amp kit at Walmart, and thats all I need. I Already have a Head Unit Up front and some Pioneer Speakers by the Rear Seats. BTW It is a 1995 Honda Civic Coupe. Thanks for the Help...
Old Aug 6, 2002 | 04:55 PM
b00gers's Avatar
b00gers
a pair of 2ch RCA wires goes from the headunit to the amp.
power wire goes from battery to amp, fuse near battery
ground wire goes from amp to chassis
turn-on wire from headunit to amp
+ on amp to + on sub
- on amp to - on sub
that basically covers it. if you dont understand something, or want more detail, just post.
Old Aug 10, 2002 | 05:37 PM
Paulll's Avatar
Paulll
Hail Bent
Hey will. I'm very new with Audio setup. I'm going to go to the store. What do I Need to get. Also, I have heard about Amp Kits, is that what I need? The smaller the words you use the better Thanks
Old Aug 10, 2002 | 06:38 PM
b00gers's Avatar
b00gers
either a 4 or 8 gauge amp kit. it should come with everything.
Old Aug 10, 2002 | 06:51 PM
Paulll's Avatar
Paulll
Hail Bent
Which one is better?
Old Aug 10, 2002 | 06:53 PM
b00gers's Avatar
b00gers
8 gauge is enough for now. 4 gauge if you plan on upgrading anytime in the future. naturally, 4 gauge is more expensive.
Old Aug 10, 2002 | 06:55 PM
Paulll's Avatar
Paulll
Hail Bent
:bowdown: to Will
Thanks man, I'll make sure I get Pics when its all done
Old Aug 10, 2002 | 07:13 PM
b00gers's Avatar
b00gers
Originally posted by Paulll
:bowdown: to Will
dont do that.h:
good luck with it.
