need radio help
Old Mar 14, 2004 | 07:58 AM
TryToStopMe579's Avatar
TryToStopMe579
Default need radio help
i just started fixing up a 1990 integra gs 3-dr...one of the first things i noticed is that my radio won't come on and the fuse isn't burnt...it's an acura radio, do i need a code for it???also the power seat belt and power window on the passenger side don't work, the fuses are good...n e suggestions, i'm sure the window's switch just needs to be replaced, but i have no idea about the power seat belt...n e help???
also, i'm new to imports...is 1990 a second generation integra???if not, what generation is it?
Old Mar 14, 2004 | 10:27 AM
b00gers's Avatar
b00gers
yes, the 1990 is the first of the 2nd generation integras.
give some more background on your situation. have the radio EVER worked? also with the seat belts and windows. if your radio needs a code, it will come on and ask for it. if you know how, you can pull the radio and see if power is actually going through the 12+ wires. then you can start to deduct and see if you run into the problem.
Old Mar 14, 2004 | 12:13 PM
TryToStopMe579
ok, well, i just got the car a while back...the battery has been out of it until yesterday...when i turn the headlights on, the dash lights come on and the dials on the radio light up...my drivers seat belt works and my drivers window works...the window was working on the passenger side this morning, but it stopped again and the seatbelt on the passenger side hasn't worked since i got it...i'm guessing the motor is messed up but i haven't taken the side panel off the inside of my teg yet...and i'll check the radio...if u know n e thing else that might help it would be greatly appreciated...thanx again
WolfGang
Dimi
4
Feb 15, 2004 01:46 AM
Daniel
News & Rumors Archives
9
Sep 12, 2003 07:46 AM
noyintegra
Jun 26, 2003 10:45 AM
yeatsisdead
Accord
17
Mar 20, 2003 10:19 AM
crucial Si
92+ Civic/EL & Del Sol
14
Oct 24, 2002 02:17 AM
