Removing speedometer in an 96' accord
Old Mar 9, 2004 | 10:26 PM
LjN_728's Avatar
LjN_728
Default Removing speedometer in an 96' accord
I'm trying to take out the speedometer in a 96' accord 4dr and I ran into a problem. In order to remove the speedometer, you first have to remove the black dash that covers the speedometer, a/c, defroster, etc...Where are all of the screws? I know there's two up on top of the speedometer window, 1 where the cruise control switch is and 1 where the defroster is. Where else? And when after taking them out, how do I take the dash out? TIA!
Old Mar 10, 2004 | 06:21 AM
AccordinglyDone's Avatar
AccordinglyDone
Wicked Kustomz, CC
remover the cruise control box with a flat head screw driver. remove the defrost you will also have to remove you cd console which requires you to take two screws out of the cuby hole theres a plat remove it to get to two screws in cuby. remove cup holder by just pulling up remove the three screws and slide whole console back to the back. you will see two screw on either side of the frame that holds the cd player in remove those. then take out the ash tray you will see a screw behind it remove. then pop out the cd dash. behind each cruise and defrost are screws that hold the dash in remove. thane remove the screws that are located behind the cd dash should be two remove. last but not least unplug conections and pop out dash. let me know if you need help with the removal of speedo careful not to break the pin on speedo. ggod luck
metpage
Aug 11, 2003 07:45 PM
Ecnocyte04
Accord
21
Jul 24, 2003 04:15 AM
jaje
News & Rumors Archives
3
May 9, 2003 09:11 AM
jaje
May 8, 2003 06:32 AM
