cd player mount trouble
Old Mar 5, 2004 | 02:51 PM
REYNOLDS TEG's Avatar
REYNOLDS TEG
Default cd player mount trouble
i recently put a cd player in my car
i had to buy a cd player mount kit to install it
the cd the player is just sitting in the mount not bolted down or nothing
when i take off fast it slides out some times
are there mounts out there that holds the player tighter for it does not slide out?
thanks
Old Mar 5, 2004 | 05:31 PM
rcurley55's Avatar
rcurley55
read the sticky - we can't read your mind - what cd player, what car?
Typically your head unit will come with a mounting cage. If you read the installation instructions for your player it will show you how to use the cage to properly attach the CD player...
Old Mar 6, 2004 | 05:33 AM
REYNOLDS TEG
the player is a aiwa cdc z137 and i have a 91 integra rs
i'm going to find instructions online
i bought the player from a friend and he didn't have instructions
yeah i have a mounting cage
going to get some help from someone
Old Mar 6, 2004 | 06:17 AM
rcurley55's Avatar
rcurley55
if you have the cage, then you mount the cage first. Mount the dash kit first in the dash. Then slide the cage into the hole. Make sure it sits all the way back and is flush against the kit. Then use a flat bladed screwdriver to bend the tabs on the cage out so that the tabs wedge the cage against the kit. Do a few on each edge so that the cage is very strudy.
Then add your wiring and slide the CD player into the cage and voila! You are done.
www.installdr.com may have some useful tips for you.
civicexstacy00
Aug 14, 2003 07:30 AM
epoxy
Prelude
Jul 1, 2003 08:44 PM
Dead_Poet
CRX & Pre 92 Civic
4
May 27, 2003 08:36 AM
tritonstudio
May 15, 2003 04:09 AM
92teggsr
Aug 7, 2002 11:11 AM
