Lights Dim When Sub Hits
Old Aug 1, 2002 | 12:44 PM
LjN_728's Avatar
LjN_728
yes most def invest in a capacitor! I wouldn't necessary change the power cable, unless u kno forsure u're using the wrong guage. but yea...just get a cap!
Old Aug 1, 2002 | 01:18 PM
dlh1999's Avatar
dlh1999
Runs with scissors.
Originally posted by steveng
there was one thread about cap stuffs that you must read.
Hey, I seem to remember that thread...:thumbup:
Rule of thumb is 1 farad for every 1000 watts of power, so in your case a .5 farad cap might do the trick. Like what steveng said, try to track down that other thread about caps...it might help clarify some of the debates about caps and questions you may have about them. I won't get into here, but I could go either way on whether or not a cap is effective. In your case, it sounds like when you crank the stereo the lights tend to dim. Assuming you've wired with sufficient wire and your battery/alternator are fine, a cap may do the trick. But it wouldn't hurt to get your system tested...lots of shops do it for free and can tell you whether or not your stereo is trying to draw too much power for what your car's electrical system can produce.
Old Aug 1, 2002 | 03:25 PM
derf's Avatar
derf
Spec5
a higher outputing alternator will make you slower too btw. i suggest cap i'm in process of buying one. what v12 amp are you running? i have th MRV-T707 wchi is 340 rms at 14.4 (never at that tho... hence buying cap).... its runnin on some gauge wire i forget... not HUGE... so its probably not 4..
Old Aug 1, 2002 | 03:43 PM
steveng's Avatar
steveng
i have mrv-t707 too. how do you like it so far? i've never had a problem with it and it has enough power i need. i use it to power one 10", but soon im gonna switch it for the front speakers and add one mono for sub(s)
Old Aug 1, 2002 | 10:00 PM
Cashis EG8's Avatar
Cashis EG8
Registered Rota Dealer
I'm going to guess that the lightning audio amp kit you bought that's rated at 350watts is probably a 8ga kit. It would be nice to have had a 4ga kit instead, but I don't think that the wire is the problem. A 1/2 farad cap might help the probelm, but I doubt it would solve it. I would guess that it is the weak alternator. You can get your stock alternator rewound at some places for about $200, and it will be able to put out more current.
Old Aug 20, 2002 | 07:22 AM
MartyMarGSR's Avatar
MartyMarGSR
JRSC GSR
fixed. I took off more of the wiring around the end of the ground wire and spread it out and sanded down the paint on the frame of the car where I had the ground attached to a bolt and bracket that holds in the backseats. Dimming has been minimized.
Barely noticable now, when earlier it almost looked like i was flashing oncoming cars.
Old Aug 20, 2002 | 07:29 AM
b00gers's Avatar
b00gers
bad ground....cool.
jax
92+ Civic/EL & Del Sol
Nov 27, 2005 06:11 AM
fxpguy
5
Oct 20, 2004 01:01 PM
