Whining in speakers.... :(
Old Jan 17, 2004 | 04:18 PM
Fiend's Avatar
Fiend
Default Whining in speakers.... :(
Firstly, I appologize for the lengthy-ness of this post!
Hey guys, I'm new to Honda-Acura.net and new to owning a Honda. I just got a gold 1993 Honda Accord SE. I'm excited about it, and I'm in the process of getting all the little kinks out of the system.
So my first question is... what is it that is making my speakers whine with the acceleration of the car and follow the RPMs. Also, the signal gets stronger when any lights are activated (headlights, blinkers, brakes, etc.).
I have looked around for the past few days on other forums and I decided that you all seem to be knowledgable and could help me out. I have read lots of stuff that it COULD be...
1. Spark plugs/spark plug wires (replaced em; noise remains, but car runs a bit nicer! )
2. Alternator 'noise'. I have yet to understand what this is and how it's a possibility, but I've heard it over forums and by a friend or two....
3. The built-in premium sound amp from Bose.
My guess is since 1 didnt work and I dont understand 2, I was going to try to BYPASS my Amp (but I cant find a wiring diagram ANYWHERE), but I just want to get some other suggestions/comments and maybe one of you has a diagram for me to use to splice the cords in the trunk to bypass the amp so my head unit will just power the speakers, instead of the amp...
I simply don't know... someone help me!!
Old Jan 18, 2004 | 12:41 PM
rgbpmp's Avatar
rgbpmp
It could be a poor ground, either for the radio, or the factory bose amp. Im not to familiar with systems with a factory amp but some times a poor ground can cause noise. Maybe try to find another place by the radio to ground it with some good wire. Strip the paint off the place you use to ground it if you decide to try.
Old Jan 20, 2004 | 06:36 AM
Spyfunkr's Avatar
Spyfunkr
I think that system may have powered speakers---iow, an amp at each speaker. Pull the head unit and check the wiring. Someone may have installed an aftermarket head and then replaced it incorrectly. If you plan to add of modify your sound system , forget troubleshooting it and dump the system. Its a hard pill to swallow, but Bose sucks and you can integrate anything into it without re-engineering it.
Spy
Old Jan 20, 2004 | 12:55 PM
Nelson's Avatar
Nelson
Administrator
My first guess is a bad ground.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Jan 20, 2004 | 01:55 PM
rcurley55's Avatar
rcurley55
Read the sticky!!!
First tell us what components are in your system. First guess is going to be a poor ground somewhere in the system...
Old Jan 20, 2004 | 05:52 PM
KuttinEdge's Avatar
KuttinEdge
A bad ground may be the case. If not, take a look and see where the main power cable is located. What happens is that the power coming from the alternator (AC power) can leak into signal carrying cables that run parallel to it (has to do with the electromagnetic feild given off). As the engine revs, the AC frequency from the alternator increases. Chances are you hear it in your tweeters and midrange before you hear it in the subs because it is at a fairly high frequency. The person before you may have installed an aftermarket stereo and put it back together half ass. To fix, run the power cables on one side of the car and the signal carrying cables on the other.
Old Jan 26, 2004 | 09:05 PM
honura's Avatar
honura
Seni
Yeah try to find a ground if not radio shack has a filter !
Old Jan 27, 2004 | 03:14 PM
Spyfunkr's Avatar
Spyfunkr
Filters are band aids. Find the root of the problem.
Spy
