Just thought I'd Share !
Old Nov 30, 2003 | 05:35 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Originally posted by lime91crx
do you know or could you find out what i have to do to make a 89 integra mototr its a d16a1 with dual overhead cams but my crx is an hf what do i need to do to make it fit. i was thinking an si transmission but i wanted to see first
:eh:
wtf are you taking about and what does that have to do with his speaker box?
Old Nov 30, 2003 | 07:12 PM
honura's Avatar
honura
Seni
Originally posted by cobbcustomz
good to see you used specs/divider. Nice work. what color vinyl you gonna go with?
Umm a flat black Vynal color ! Im gonna have the JL Audio engraved in the box b4 Wrapping it so that you can see it on the vynal . Should be hot !
Originally posted by westcoaststyle
:eh:
Can you say NEEEEEUUUBBBBBBBBBBBBBBB . Lol Thats was too funny man ! AHHHH poor guy .
Old Nov 30, 2003 | 07:36 PM
EJcivic02's Avatar
EJcivic02
I talk Before I think
i dont know about vinal, might looks kinda tacky and cheap.
dont worry, you were in his shoes not too long ago
Old Nov 30, 2003 | 07:40 PM
honura's Avatar
honura
Seni
LOLOLOL Yeah I know but I would never jump into a tread and bust out a question on another topic lol . Thats too funny either way you look at it hehe .
Yeah and vinal I was thinking about that as well but it will cost me $5 to see what it looks wrap in vynal so if I dont like it I'll get rid of it quick fast ! trust me sometimes the stupid ideas turn out good .
Old Nov 30, 2003 | 08:00 PM
lkailburn's Avatar
lkailburn
college kid
NOT VINAL, its VINYL
Old Nov 30, 2003 | 08:17 PM
A_D's Avatar
A_D
Reset?
ok first of all its not absolutely nessicary to have seperate chambers for 2 subs. when i get my eD 12O's, i'm doing a common chamber in a 3cuft box. its actually easier that way because you dont need to calculate exactly where to have the divider for the chambers, because if you're off by a half inch or so, guess what? you're volumes for each chamber are going to be different.
its also better to do it this way esepecially for ported boxes because you don't have to make two ports and try to tune them exactly the same. if you do it with a divider and try to tune two different ports exactly the same and you're off by say half an inch again on the port, guess what? you have the same two subs playing the same frequencies, but since they're at two different tuning frequencies because of that half inch, you're most likely gonna get some cancelation. so its actually better to do a common chamber do a sum of the volumes/port volumes so there is absolutely no mistuning of your enclosure
secondly, whoever said you have to figure out the proper volume for a box if its sealed/ported, well thats kind of obvious. but proper is in the eye of the beholder, depending on what kind of sound/output you want from your system
you also need to know your tuning frequency as well when you have a ported box
third, you don't ALWAYS have to build boxes to manufacturer's specefications. don't be afraid to experiment.
do you think SPL competitors acheive huge numbers with 4 15s by adding up the recommended sealed or ported volume and tune it to like 28hz or something low (if ported)?
no, they make enclosures with bigger volumes, tuned higher because that will typically increase output.
typically a manufacturer's enclosure blueprint is a good recommended volume/tuning frequency, but you don't always have to go by these standards. it all depends on what kind of sound and output you want from your driver
Old Nov 30, 2003 | 08:27 PM
rcurley55's Avatar
rcurley55
If you can't put a divider in the middle of the box, then you shouldn't be building boxes - off by 1/2" - I can eyeball that kind of measurement...
While manufacturer's specs are not the law, generally, they provide good all around performance for most users.
True SPL boxes are one note wonders and are worthless for playing that stuff called music...
Old Nov 30, 2003 | 08:29 PM
rcurley55's Avatar
rcurley55
and one more thing, fix your photos!!
Old Nov 30, 2003 | 08:36 PM
A_D's Avatar
A_D
Reset?
yes half an inch is a pretty bad gap but i was just giving an example
i already stated the same thing about the manufacturer's specs as you did, i just worded it differently
and i already knew that spl boxes generally sound like a wet fart except hitting the tone they're tuned at
Old Nov 30, 2003 | 09:08 PM
rcurley55's Avatar
rcurley55
I guess I'm more of a proponent for dual chambers...
For one, it acts as a brace for the box, making it stronger. Secondly, if one woofer dies, then the other will still work just fine. For sealed boxes it's a no brainer. You have a good point for ported boxes, or even fiberglass boxes...
