amp affecting idle?
Old Oct 29, 2003 | 07:22 AM
sick79's Avatar
sick79
Default amp affecting idle?
i searched but came up empty. ne ways, i notice that when i have my stereo on that my idle jumps around. when my stereo is off it idles decently. i thought that maybe the bass was just causing the stock tach to move but i popped the hood with the stereo on and the engine didnt sound smooth. i turned off the radio and it was fine. i only have a 250 watt amp hooked up to one twelve, so its not a massive amp drawing to much current. any ideas? thanks.
Old Oct 29, 2003 | 05:24 PM
SumAccordGuy94's Avatar
SumAccordGuy94
Older Honda Fanatic
any sudden current draw will make the motor bog down a little, as the extra current puts a load on the alternator putting a draw on the motor.
Old Oct 29, 2003 | 05:32 PM
sick79's Avatar
sick79
any tips on how to alleviate the problem or should i just chuck my amp out the window doing 110 on the highway. because i cant stand my motor bogging like that? thanks.
Old Oct 29, 2003 | 08:48 PM
SumAccordGuy94
Older Honda Fanatic
you can try a capacitor... it'll help a little
Old Oct 30, 2003 | 06:46 AM
sick79's Avatar
sick79
thanks.
Old Oct 30, 2003 | 07:48 AM
smokedogg's Avatar
smokedogg
if you have the cash, you could always get a high output alternator. example
Old Oct 30, 2003 | 09:23 AM
Kevin's Avatar
Kevin
Banned
its the sign that ur alternator is going bad...
u can try to do the magic 3 and it might help...but eventually ull need another alt
Old Oct 30, 2003 | 09:58 AM
sick79's Avatar
sick79
if its not one thing its another with this car. what do you mean by magic 3?
Old Oct 30, 2003 | 11:51 AM
Kevin's Avatar
Kevin
Banned
try this...
4 or 2gauge from battery + to amps
4 or 2gauge from amp - to good grounds
4 or 2gauge from battery - to chasis
2gauge from alt to battery +
then 4 or 2gauge from engine block to battery - or good chasis
i may have missed out on something..
but an upgrade in ur current electrical wiring helps...
esp grounding and ur alt
Old Oct 30, 2003 | 12:04 PM
sick79's Avatar
sick79
i may have to try that. i already have a grounding kit on my car, i probably need to upgrade the positive side now. thanks for the advice.
