I'm diggin this set up
Old Jul 19, 2002 | 06:02 PM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
Originally posted by GotRice_B16a
now, this is a good hatch set-up! If I only knew how to do it..
is it just me or does that have too many amps?
a cookie to the first person to figure out what car that is!
Old Jul 19, 2002 | 07:53 PM
Kirby's Avatar
Kirby
It's a freakin toyota supra!! Look at the dash see how it surrounds the driver, and look farther see the surpa in the f&f scene. I thought it was an easy question
Old Jul 20, 2002 | 02:58 AM
Fujiwara Takumi
It's my first day.
i drive a fucking civic, and make less than 30k a year, ive never even seen the inside of a supra.
an insight would be cool though.
Old Jul 20, 2002 | 08:52 AM
rcurley55's Avatar
rcurley55
Originally posted by fujiwara takumi
i did a similar setup as i described, in my truck, with only wood. fiberglass would be too heavy.
Whoa partner...a properly installed 'glass enclosure will be lighter then any wood one you can build. Don't know where you heard that one, but the above is false...wood is much heavier.
Old Jul 20, 2002 | 09:02 AM
b00gers's Avatar
b00gers
looks like a supra....the dash is slanted towards the driverside.
Old Jul 20, 2002 | 09:35 AM
Fujiwara Takumi
It's my first day.
not always. you have to back that fiberglass with something, you cant just lay sheets of it out and call it a day.
Old Jul 20, 2002 | 10:19 AM
rcurley55's Avatar
rcurley55
Actually, you can -- it's not that elementary, but you can build tons of things out of just glass...nothing else. A few layers of Knytex with the appropriate resin will be extrememly strong.
You can make a sub enclosure using 'glass that is only 1/8-1/4" thick if you design it properly (depending on the application of course).
I don't know if you have ever designed or worked with composites before, but you could make a box out of 90% fiberglass if you wanted to, and it would be extrememly light and you could use it as a jackstand.
Composites are a trade off in many aspects, but the main advantage is it's strength to weigth ratio....why do you think carbon fiber is so popular?!?
Old Jul 20, 2002 | 02:29 PM
Guest
Guest
Posts: n/a
it seems like too many amps, but my gues is its 1 to each sub, then one to the front speakers, then one to the back speakers, or, some of them could be "dumbies" to make everything symetrical
Old Jul 21, 2002 | 03:11 PM
integramodder's Avatar
integramodder
:ghey: :ghey: :ghey: :ghey: :ghey: :ghey:
Old Jul 21, 2002 | 04:11 PM
Guest
Guest
Posts: n/a
i dont know, was just a thought. besides when you got money you can buy extra amps that you aint gonna use:squint:
