arg I really need help!!!
Old Sep 23, 2003 | 08:59 PM
trev's Avatar
trev
Act Accordingly
Default arg I really need help!!!
ok so people tell me it's easy to take my gauges off, just slip the pin throught the hole.... the only problem is the hole is to small to fit the needle through. The needles base has a black plastic piece around it thats too big for the hole... how the **** am I supposed to get the gauges over the pins when the holes not big enough??????? Can someone pleeeeease help me, I know most people have done it before because theres so many glow gauges out there. :upset: :upset: :rant: :rant: :cry: :cry:
Old Sep 23, 2003 | 09:08 PM
vtecaccord01's Avatar
vtecaccord01
Performance isn't $$$
did you try and search on the topic.
Old Sep 23, 2003 | 09:10 PM
trev's Avatar
trev
Act Accordingly
yea I couldnt find much, do you know?
Old Sep 23, 2003 | 09:11 PM
trev's Avatar
trev
Act Accordingly
pleeeease tell me!!! I see you did put indiglo dash on, I really need the help!
Old Sep 23, 2003 | 09:25 PM
Illicit Accord's Avatar
Illicit Accord
dude calm down.... first off when you get the gauges, ur just supposed to slide them on the needle and stick them in place.... i can draw you a pic if you want........ get back asap
Old Sep 23, 2003 | 09:33 PM
trev's Avatar
trev
Act Accordingly
I dont have indiglos though.... I just want to take the stock gauges off, slip some red filem under them, then put the gauges back on. Im doing this to change the color of the numbers. Have you ever removed the stock gauges?
Old Sep 23, 2003 | 09:38 PM
Illicit Accord
DO NOT REMOVE THOSE GAUGES!!.... IF YOU TAKE THE NEEDLE OFF YOU WILL **** THEM UP, AND THEY WILL NEED TO BE RECALIBRATED..... no i've never done it.... and i don't think it can be done because that peace is just one piece,you can't put anything under it, plus it wouldn't make a diff, because ur gauges don't glow.... a light shines down on them
Old Sep 23, 2003 | 09:41 PM
trev's Avatar
trev
Act Accordingly
but theres lights under them too. If I use red lights it makes the numbers pink because they are already white. But if I put red film under them Im hoping to get it even more red
Old Sep 23, 2003 | 09:42 PM
Illicit Accord
dude the lights under them are for the milage and that shit
Old Sep 23, 2003 | 10:16 PM
Weiman's Avatar
Weiman
u can take out each gauge individually by taking outthe whole cluster disconnect wires and pull out the cluster...then unscrew the screws in the back connecting the pieces...around 3-4 for each gauge....but do this at your own risk iv done it b4 to reinstall a gauge..but i never tried to replace a film..
