Door Lock Whirring
Old Aug 19, 2003 | 02:06 AM
yldstyleviet's Avatar
yldstyleviet
Default Door Lock Whirring
95 Accord EX
When I hit lock from my alarm or inside of door, it locks. When I hit unlock, half of the time it won't lock and will make a spinning-motor, whirring sound. I have popped the inside panel and the sound is coming from the white/yellowish plastic box that is connected by a coat-hanger size metal pole. From the search I've done, i think it's the actuator. someone confirm this for me. thanks
Old Aug 19, 2003 | 11:50 AM
vinz's Avatar
vinz
Default Re: Door Lock Whirring
Originally posted by yldstyleviet
95 Accord EX
when you hit unlock, it wont lock ? of course it wont lock it will UNLOCK YOUR CAR. REMEMBER YOU HIT UNLOCK.
Old Aug 19, 2003 | 01:28 PM
Baco95's Avatar
Baco95
that just ain't baaalla!
I know exactly what sound you are talking about....
My front passenger door has been doing it for months now...but the lock would still work. Just recently I've noticed that when unlocking all the doors, that door sometimes doesn't unlock.....think we have the same problem.
Old Aug 19, 2003 | 04:12 PM
I Like JDM's Avatar
I Like JDM
JDM Spec Tuner
You replace the door lock module...the buzzing sound will go away.
Old Aug 20, 2003 | 01:08 AM
yldstyleviet
Default Re: Re: Door Lock Whirring
good call :fawk:
So do I need to replace the actuator or the module? I went to Honda today and they wanted $90 for the actuator
Old Aug 20, 2003 | 01:53 AM
93accord4door's Avatar
93accord4door
upgraded to 97 ;]
i have the same problem with my car, and so did my mom and my boy and every1 else i know that has a 5th gen...just replace the module, how much should this cost?
Old Aug 20, 2003 | 10:22 AM
sickhonda's Avatar
sickhonda
Yes, you need to replace your door lock actuator. You can either get it used at the local salvage yard or at ebay for less.
Good Luck!
Old Aug 20, 2003 | 08:20 PM
SpeCKDriFt96's Avatar
SpeCKDriFt96
Ohhhh F buying a new one, i opened up my actuator for that same problem and the only thing wrong with it was a ripped block of rubber. And its funny cause all u need to do is find something to absorb the shock from the motor in the actuator( in my case, i used a little slitther of an eraser and jammed it in there) . I know this sounds confusing but i can elaborate more if u want me to. just reply or PM me. HEY, its better than paying $90 for something u can fix ureself!
