95 Accord Radiator Fluid Leaking OUT
Old Jul 18, 2003 | 07:14 AM
accord2fix's Avatar
accord2fix
Default 95 Accord Radiator Fluid Leaking OUT
My Accord's radiator fluid keeps overflowing out of the resevior after I drive it for over 10 minutes or so. There is no problem (yet), when I am driving the car. When I stop, there are gurgling noises and RF comes out of the resevior. My RF is between min and max, when the car is cool and radiator is full with RF. What do you guys think the problem is, water pump, thermostat, or bad radiator. Whatever you think the problem is, please explain how I would go about identifying if it is acutally the problem.
THANKS!!
Old Jul 21, 2003 | 07:14 AM
JimBlake's Avatar
JimBlake
I think your water pump would either leak or make nasty noises. I can't think of a realistic way for it to stop pumping. If it's shaft broke you'd throw your timing belt & you would probably notice that...
T-stat or radiator should make your engine run too hot. How does your temperature gauge run?
A blown headgasket can make bubbles in your coolant. A leakdown test can check that.
Make sure the radiator cap and the hose going to the reservoir are OK. As the engine cools down, it's supposed to suck coolant back into the radiator. If the hose leaks then it sucks air instead of coolant. Those are easy to check before you go looking for exotic problems.
