change rear disc brake
Old Jul 9, 2003 | 09:21 PM
laboyae's Avatar
laboyae
Default change rear disc brake
Hi anyone,
I know how to change rear drum type brake, but rear disc brake is new to me, anyone has a step by step instruction telling how to change rear disc brake on my 2002 LE V6 Accord. Thanks.
Old Jul 10, 2003 | 10:20 AM
(98)2DrAV6's Avatar
(98)2DrAV6
Jigga wut?
I just did mine so ill write it up real quick.
Loosen lugnuts, then jack up the car.
take wheel off.
Unbolt 2 screws, youll need an open end wrench for the top one since the e-brake is connected and wont allow a socket inbetween. There is also a little metal piece that youll need to hold while you unscrew the bolts.
Take the caliper off and take out the pads.
Put the new pads in .
Take a BIG flat tip screwdriver and rotate the piston clockwise to push it in, cause it has to fit over the new pads.
Bolt the calipar right back up. Easy peeze... I did the whole brakejob (front and rear) in an hour and a half.. Hardest part is the ****in pistons. Oh yea dont forget to take off the top of the brake fluid under the hood otherwise you wont be able to get the piston to retract.
Old Jul 10, 2003 | 10:23 AM
WarptEra's Avatar
WarptEra
& since the e-brake must be off, put behind under your wheels when it's jacked up.
the changes of it rolling off the jack are way slim but its just a smart thing to do. its the type of accident that you don't want to have to tell people happened. you know, cuz its so easy to prevent.
-w
Old Jul 10, 2003 | 12:04 PM
Josher's Avatar
Josher
Instead of a big screwdriver to send the rear piston in, you can just you some needle nose pliers.
Also, use some of that anti-squeal on the back of the pads.
I'd reccommend some of the Permatex Anti-Seize for the brake sliders along with all the bolts too.
Old Jul 10, 2003 | 08:51 PM
laboyae's Avatar
laboyae
Thanks to everyone, I am going to try it on Sat.
Sounds like it is easier to change rear disc brake than drum.
Old Jul 18, 2003 | 08:41 AM
sharrison's Avatar
sharrison
I did this on my 2001 Accord (rear disk with abs) last night, but have a problem with the pads rubbing.
My brake piston has a "crosshair" pattern on its face. I think, when I turned the piston (which was an accidental discovery BTW) I didn't make sure the bump on the back of the new pad lined up in one of the crosshair groove. Is it supposed to? And does any re-adjustment need to be done for the parking brake to account of the new pads?
Thanks.
Scott
Old Jul 18, 2003 | 09:48 AM
rage's Avatar
rage
I recently changed my 6th gen brakes, lol after reading this thread.
It was really easy.
The steps above work good.
That anti squeak grease stuff seems to work, I recommend it since its cheap.
Make sure you take the master cylinder cap off (main brake fluid thing under the hood) Also it’s a good idea to wrap a rag or 2 around it because a tiny bit of fluid will prolly spit out. You shouldn’t need to top it off or anything.
The only problem I had was pushing the piston back into the caliper. Maybe I didn't do it right, but I couldn’t get it back in with a flathead or needlenose. Instead I used a C-clamp. That worked a lot better. After I did my first brake I grabbed one of those pistol grip clamps, and that worked like a champ on the rest.
As soon as I drove the car, there was little pressure on the brake pedal, pumping it a few times stiffened it right up, I assume this is normal.
After that, the petal was a little too stiff. I drove it for a little, braking like crazy, then floored it in reverse, and braked a bunch. (I read that this was a good idea to help the brakes self adjust)
After about 5 min of driving my brakes were back to normal, and of course working better cause they are new. You might notice an odor from the new brakes or possibly a few drips of brake fluid burning off of something
Old Jul 18, 2003 | 01:31 PM
jschmid's Avatar
jschmid
You actually don't NEED to remove it, it will overflow out if you max it out, it's built to allow for overflow.
