Ignition Kill Switch or Fuel cut-off switch.
Old Jun 2, 2003 | 10:41 AM
vtecaccord01's Avatar
vtecaccord01
Performance isn't $$$
Default Ignition Kill Switch or Fuel cut-off switch.
Does anyone know where to get one or how to make one. not the kill switch that comes with the alarm, those can be bypassed, I mean a seperate one or a fuel cut-off switch. Want to make sure she has the most protection.
Old Jun 2, 2003 | 10:43 AM
decibel_dj's Avatar
decibel_dj
honestly anything u can install can be bypassed theres no way around it.
Old Jun 2, 2003 | 10:44 AM
vtecaccord01
true but the more to bypass the more frustrated they will get. Just wanted some extra security thats all
Old Jun 2, 2003 | 10:46 AM
decibel_dj's Avatar
decibel_dj
i guess, its just more homework for the theif and more work for you to get into and out of your own car in the process
Old Jun 3, 2003 | 04:45 AM
vtecaccord01
Doea any know?
Old Jun 3, 2003 | 09:12 AM
Accord1278's Avatar
Accord1278
get yourself a repair manual and find the wiring diagram for the fuel pump. splice the power wire and stick a toggle switch in between and hide the switch somewhere. when the toggle switch is "off" and you start the car, it'll start but only last a few seconds before it shuts off. make sure you put it somewhere where you can't turn it off by mistake cause that'll be pretty bad driving down the highway and have your fuel pump go off.
or you can find the starter wiring diagram and do the same thing with it, which is probably safer than the fuel pump thing.
Old Jun 3, 2003 | 09:27 AM
KAUAI KANE's Avatar
KAUAI KANE
91' Toyota Supra
From: Iwakuni, Japan. And where ever the Marine Corps sends me
or do both? :dunno: will that work or do you think it will be to much of a hassle i remember my older brother had one for his fan fuel and starter but then again it was a 70-79 datsun p/u with a 283 in it so he had to do it
Old Jun 3, 2003 | 11:04 AM
proteus's Avatar
proteus
it will be a hassle, not worth it imo. If you watched 44 Minutes on sunday you saw how the robber could not get away in the truck because he could not get it started because he did not realize there was a fuel cutoff switch.
Old Jun 3, 2003 | 11:27 AM
vtecaccord01
So protues your saying not to do it or do it?
Old Jun 3, 2003 | 11:32 AM
Customlowz's Avatar
Customlowz
Speedbumps Beware
what about puting in a second ignition???
