Fuel Quantity Gauge
Old May 28, 2003 | 07:58 AM
Belmar's Avatar
Belmar
Default Fuel Quantity Gauge
My Fuel Quantity Indicator is just crasy. The needle of my 94 Accord do not indicate the right quantity. Sometimes, the tank is full and my gauge shows an empty tank.
Someone have that problem before ???
Thanks
Old May 28, 2003 | 08:03 AM
decibel_dj's Avatar
decibel_dj
you may have a short somewhere but the fuel gauge runs off a buwee (sp?) right? if so then you have a wiring problem somewhere. you can always have it checked or buy an aftermarket gauge
Old May 28, 2003 | 08:20 AM
Belmar's Avatar
Belmar
Thanks for your comment,
However, I think it as something to do with the probe in the tank itself because the indication never goes off completly. I have sometime low fuel light on. Also, the needle never reach the "Full" line even when just fill the tank.
By the way, your logo at the end of your message is very cool !
A bientot (in french)
Old May 28, 2003 | 08:30 AM
decibel_dj's Avatar
decibel_dj
its all good :thumbup:
Old May 28, 2003 | 08:47 AM
JimBlake's Avatar
JimBlake
The sender for that gauge is in the tank. On the 6th gen its mounted in with the fuel pump, maybe '94 is similar. There's a float on a lever. You get to it thru the floor of the trunk, there's a round cover you take off. Then you see the actual fuel tank, take off that next cover & pull the whole unit out of the gasoline. Try not to set it on fire when you do this...
Old May 28, 2003 | 11:13 AM
pirate252's Avatar
pirate252
I have a 94...it does kinda the same thing, never reaches the full when i fill it up, never goes up past the 3/4 mark...its all good though just makes me think its empy when it still has a quarter left...
Old May 28, 2003 | 05:40 PM
AccordManiac's Avatar
AccordManiac
Korean Member
I have same problem with my current 93 Accord!
Here is the link that I posted this problem.. while ago. .. from hondasociety....
http://board.hondasociety.com/showth...ght=fuel+guage
My fuel guage problem.... need to replace the fuel meter assy..
I still didn't fix the problem.... lol!
Old May 29, 2003 | 08:27 AM
JimBlake's Avatar
JimBlake
I just saw another thread like this about 5th gen Accords on, ummm, another BB. I guess you have to drop the gas tank because when you open the access cover in the trunk, it doesn't line up with the pump/sender assembly. So it might not be as easy as I made it sound...
