Washed my engine
Old May 27, 2003 | 07:12 PM
mpykalo's Avatar
mpykalo
Default Washed my engine
Finally washed my engine. The car is 20 months old now (18600 miles) and it was getting a little grimy in there. Some pics:
My next mod is the AEM CAI.
Old May 27, 2003 | 07:27 PM
cooliojones's Avatar
cooliojones
how did you protect various parts so water didn't get in the intake or vital engine parts? did u take it to a car wash?
Old May 27, 2003 | 07:37 PM
F23A4_AcCoRdude's Avatar
F23A4_AcCoRdude
Ok. Explain in details the entire procedure that you follow to clean your engine bay. A lot of people are curious on this topic. Thanks.
Oh yea, check out my sig for the aem.
Old May 27, 2003 | 07:40 PM
jschmid's Avatar
jschmid
Looks great.
Old May 27, 2003 | 08:11 PM
Samson's Avatar
Samson
chris is the devil
so how did ur headlight squirters end up working? i think u should color match them... that would look smooth.
Old May 27, 2003 | 08:29 PM
jschmid's Avatar
jschmid
I second that, it'll look cleaner that way. Or get real trick and mount them on a thing that slides up when in use and then hides under a cover like the Audi, etc ones.
Just paint them to match.
Old May 28, 2003 | 05:37 AM
mpykalo's Avatar
mpykalo
To wash the engine I covered the air intake, alternator and other misc. electrical connections. I used a hose (very low pressure) and a sponge. I did not use any degreasers - just lots of elbow grease.
The headlight washers are OEM Honda Accord for a 2002 German spec coupe... that car is virtually identical to the US 6gen coupe. Pic below:
Old May 28, 2003 | 05:38 AM
mpykalo's Avatar
mpykalo
OEM locations I meant to say... the actual parts are not OEM.
Old May 28, 2003 | 05:40 AM
decibel_dj's Avatar
decibel_dj
i guess you go offroading alot or something?
whats the purpose of headlight washers? wipers i can understand but washers?
Old May 28, 2003 | 05:53 AM
mpykalo's Avatar
mpykalo
These get the snow guck off in the winter... had a similar setup on my Passat. The squirters have a separate pump and work with a separate switch.
