Transmission Woes
Old Oct 24, 2005 | 09:24 AM
traible's Avatar
traible
Originally Posted by adamdaviddoyle
My 98 Accord V6 is revving up to like 3 rpms and then "ca-clunk" into 2nd gear. This is only in the morning after sitting over night... and only for like the first 2-3 mins til the engine warms up then it shifts fine. Am i in the early stages of need a new tranny? i have 70K mi. on the engine... little early for a tranny to be going isn't it? is there anything i can do to prolong this tranny? Should i take it to a tranny specialist... maybe they can adjust some of the belts or something?
me = idiot
Thanks guys
I am having similar problems with my 1998 Accord v6. Primarily when sitting for while (over night, all day at work). Shifts almost like a manual with the clutch partially depressed. Very annoying and concerning.
I have the fluid replaced at 60K-ish miles.
Dealer couldn't find anything wrong yet - no lights, no codes.
Did you find out any more on yours?
Old Oct 24, 2005 | 10:59 AM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Have you looked at any other transmission posts? It's a very common problem. If you don't have CELs then it's a bad tranny. If you have over 100k miles you won't get a dime from Honda, if you have under you might if you're a good talker. Search.
And 60k miles is not the recommended interval :slap:
