Intake Question... Solenoid/Sensor Thingy...
Old Apr 26, 2003 | 01:07 AM
AadosX's Avatar
AadosX
Default Intake Question... Solenoid/Sensor Thingy...
Yes I did a search.
Ok, I basically did exactly what this guy did...
http://www.hondalive.net/lordaccord/intake/index.html
So that means I have all the hoses for the FIA system removed, and the solenoid/sensor thing is out too, and that plug is just dangling. No CEL, and car seems to be running fine... but I'm wondering if it's ok this way?
Old Apr 26, 2003 | 07:48 AM
TJCCARDCO's Avatar
TJCCARDCO
If theres no CEL and the car runs fine, it's ok
Old Apr 26, 2003 | 02:27 PM
AadosX's Avatar
AadosX
Cool, that's what I wanted to hear, but just to be sure... and no offence hehe... anyone else?
Old Apr 26, 2003 | 04:16 PM
dantastic's Avatar
dantastic
cx power!
yea.. just cap the vaccum line and unplug the solenoid. tape the connector and thats it. i did the same on my accord when i installed my aem cai. 5 years, no probs
Old Apr 26, 2003 | 08:35 PM
Matt86's Avatar
Matt86
vtec ownz j00
how exactly do you cap off the lines?
Old Apr 26, 2003 | 10:37 PM
AadosX's Avatar
AadosX
There is only one line to cap off. AEM gives you a small rubber cap. Other than that there is one filter peice you put into a pipe to replace another hose.
Old Apr 27, 2003 | 05:24 PM
dantastic's Avatar
dantastic
cx power!
i felt taht the rubber caps that came with the filter might come off, so i used a screw. some people use golf tees
Old Apr 27, 2003 | 09:01 PM
AadosX's Avatar
AadosX
I'm prolly gonna wrap tape around it also...
BTW, theres only one capped off line right?
Old Apr 28, 2003 | 11:33 PM
AccordCoup94's Avatar
AccordCoup94
i only capped off the line that ends at the center top firewall with the little rubber cap and it hasnt fallen off for 2 years. aem also gave me this small spongy filter thing that i was supposed to stick into the other line that ends near the fuel rail. i just put a small cone breather there instead. i also had a connector that i unpluged and just left hanging. i've always wanted to ask this.. you know the line that goes from the top left of the valve cover and into the intake? what would happen if i just left that alone and covered up the intake hole? i ran my car before with that hose disconected and i felt hot air coming out of that valve cover hole so im thinking that its just blowing some kinda of hot air into the intake. whats the point of that? no check engine light came on when i did this but i still didnt want to drive with it like that untill i knew what it does.
Old Apr 28, 2003 | 11:39 PM
bonestock's Avatar
bonestock
