Throttle Body Cleaning
I used the STP or what ever that had at the auto store, so I'm not sure about the seafoam. with the stuff I used, the directions were to use the whole can, while the car is running. My car still works great.
Yeah there are two ways to get it through your intake manifold, but only one of the ways will also clean the throttle body. If your TB is clean, just spray the TB cleaner directly into the port where your PCV valve connects from the engine to the intake manifold. I'm not talking about the breather hose but the PCV valve hose.
But you know what? I can understand that the intake manifold gets carbon deposits from the unburnt gas vapors that goes from the PCV valve into the intake manifold but what about the throttle body? I didn't think air will give much carbon deposits. So it must be other junk in the air that the air filter doesn't filter that gets caught in the throttle body. And the breather hose draws air from the intake into the engine so it's not like you'd get backflow of unburnt gases from the engine into the intake pipe.
i need some help.. i took off my stock intake to clean my throttle body, and was putting the intake back on, but the problem is that i see a small hose on the bottom where i think the engine or tranny is, but i can't find where it goes? can anyone help please??
Originally posted by EliteAccord
How do you use it? Details please.
Originally Posted by b12uceHuy
:wopics:
I want some pix of how to do this
step by step:thumbup:
So number one is make sure you are well ventielated area (like OUTSIDE...I mean way outside the garage). The car does need to be at operating temperature so I recommend say going to the store and come back home. You might even want to stop by home depot and get a 1.5 ft of 1/4" clear tubing, I'll explain why in a second.
When you get home, with the engine off, disconnect the vaccum hose before (this would be the black 1/2" tubing that appears to run from the intake area to a check valve, in my '95 it was colored gray, just above the brake booster. You want to use the hose obviously before the check valve cause the check valve is only a one way deal. If you notice, the seafoam can opening is kinda small for the 1/2" black vaccum hose, so this is where that 1/4" clear tubing comes into play. Stick an end into the black tubing, and keep the other end exposed as you are going to dip that into the can. Have an assistant start the car, and have him hold the RPM's as best as he can at 2,000-2500 RPMs. Obviously don't press the brake while you are doing this, and do not have any accessories running like the a/c, or try to turn the steering wheel; stereo is fine
. Basically, with the car idling and your assistanting holding a steady RPM, dip the tube into the Seafoam can, and take out quickly, dip again and take out quickly, your assistant will complain it is starting to get harder to keep at that RPM and it feels like it wants to stall. Tell him to be patient (of course you know it will eventually). You will also see a big cloud of white smoke out the tailpipe and it might have a reaky smell to it, no biggiee, that's smoke includes carbon buildup. Continue the dipping process, until the car stalls (this is commonly known as hydrolocking), when I did this I had about a 1/3 of the Seafoam can left and I dumped the rest in the gas tank. Let the car sit for a while. Opinions vary here, as I left mine off for 15 minutes caz I was doing an a/c check on it, others say 5 minutes. Either way, by letting it sit, the seafoam helps soften up the carbon buildup. Take out the clear tubing and reconnect the vaccum line to the check valve. Start it up, you may or may not have problems doing this, but giving it gas helps, mine started up pretty well right away because of the time letting it sit, so I didn't need to give it gas. NOW the fun part, drive the living shit of the car and try to keep high RPMS, downshifting whenever possible. As you are driving you will see smoke coming out the back, that again is carbon buildup so don't fret. Try to drive for a while like on the freeway and go visit a friend or take the long way to a place. You should notice a change after all is said and done on your performance, my RPMs at idle went up and noticed a smoother idle, rather than before on a hesitating idle.NOTES:
1) I used the brake booster line as that I think is one of the largest draws on your system.
2) By using a clear tubing, you can see how much you suck up so it's not all at once, you want to try and minimize too quickly of system feed, otherwise you'll hyrdolock too quickly and won't suck up enough Seafoam. If that happens, no biggie, let it sit for a bit and start up the car and continue the process.
3) Probably want to clean your TB after doing this with the directions others have mentioned on this board. I am going to do that this weekend. Just becareful when using a brush so you don't damage the TPS sensor on the throttle body. I always say this tip, as I have damaged it before on my old 4Runner.
4) Usually whenever I clean the TB, I install a new air filter at the same time, good preventative maintenance, especially since I usually do this once a year.
This my friend qualifies as the Upper Head Cleaning that you did for about $10 that would otherwise cost $100 at a dealership.
The bottle of throttle body cleaner I have says specifically not to use while the engine is running, and that it is extremely flammable. Did I get the wrong stuff, or am I supposed to ignore the warnings and spray the crap in anyhow?
