cure for sticky throttle from idle?
Old Apr 18, 2003 | 12:52 AM
Carcrazy's Avatar
Carcrazy
Default cure for sticky throttle from idle?
my 99 Accord's throttle is getting sticky such that it is difficult to get a smooth start (w/AT) from rest, especially after a cold start. Has anyone else had this problem and what is the solution. I already tried to clean and lube the cable where possible with not much improvement. thanks in advance.
Old Apr 18, 2003 | 04:03 AM
Accord1278's Avatar
Accord1278
I've got a '98 that has the same problem here and there. I haven't done anything yet to it but plan on it. If anyone can shed some light on the subject, it'd be greatly appreciated.
Old Apr 18, 2003 | 01:10 PM
crxb16er's Avatar
crxb16er
check ur throttle cable make sure that its tight and not too lose (supposed to have a little slack, but should be smooth maybe use wd40 if necessary) clean the butterfly valve on ur intake manifold with a gunk degreaser it might be sticking. but with a 99 u shouldnt be having problems like this yet, make sure u do ur regular maintance ie spark plugs oil changes on time, if u havent done one at all u might want to do a transmission flush get all new fluid in there might make things smoother but once again a newer car like that u shouldnt have these problems, its probably jsut not feeling like a new car when its old like my 88 then u'll know cars just arent perfectly smooth all the time
Old Apr 27, 2003 | 08:46 AM
honda guy's Avatar
honda guy
clean out your throttle body, you will see the gunk inside when you open the butterfly. Spray some throttle body cleaner on a rag and work it till its clean this will fix the stickyness.
