5th Gen Firewall grommet for Power Wire?
Old Mar 20, 2003 | 02:54 PM
MikesCommuter's Avatar
MikesCommuter
As the ACCORD TURNS!
Default 5th Gen Firewall grommet for Power Wire?
Got any links or pics for this process?
Old Mar 20, 2003 | 03:06 PM
vtec94's Avatar
vtec94
what you need to do is just push the power cable through the rubber gromet thinggy. it's pretty simple, if you need to run the bigger power wire, then just use the exacto knife to enlarge the hole a bit more.
$.02
Old Mar 20, 2003 | 03:12 PM
dantastic's Avatar
dantastic
cx power!
thers one in teh pass footwell for the oem foglight harness
Old Mar 20, 2003 | 03:48 PM
MikesCommuter
This sounds Ideal....but when you say FOG LIGHTS, Im assuming its going to be a VERY LONG run...does it go OUTSIDE the car? or directly in the car?
Thanks for the quick reply!
Mike
Old Mar 20, 2003 | 06:02 PM
dantastic's Avatar
dantastic
cx power!
um... theres a hole in the fire wall there.... theres just a rubber plug were u can run a wire thru.....
Old Mar 20, 2003 | 06:07 PM
Fryd_Up's Avatar
Fryd_Up
rebmeM roineS
attach the wire to a bent out coat hanger and run it thru there, its on the driver side, by the brake fluid and clutch fluid, if you get inside your car and look on that side under the dash you'll see where all the wires run thru it
Old Mar 20, 2003 | 06:34 PM
Bl@ck's Avatar
Bl@ck
Sinner
i ran mine through the passenger side fender. you can see it when i open the passenger door, but who cares.... i guess that's what i get for not buying a long enough cable.
Old Mar 20, 2003 | 09:41 PM
AadosX's Avatar
AadosX
same thing i did
Old Mar 20, 2003 | 10:10 PM
mrsebastian's Avatar
mrsebastian
this is for 6th gen, but it may help to figure out a good spot.
http://www.morningz.com/mz/integra/a...accord_amp.asp
the coat hanger thing is the best way to push a wire through the rubber grommit and i'd go for sure through the passenger side as it's easier to "find" the wire from under the dash. took me about 5 minutes to get it done.
Old Mar 20, 2003 | 11:29 PM
MikesCommuter
Very nice thanks for the link...I'll do it tomorrow
Mike
