fog switch in OEM spot...
Old Mar 9, 2003 | 02:45 PM
bruce_91zx's Avatar
bruce_91zx
engiNERD
Default fog switch in OEM spot...
It took me about 2 1/2 hours, but my fogs are rewired. The best part is, you know how the hazard button is on the left on the center console?, on the opposite side there's a cover for the place an OEM foglight switch would go, I took that cover and cut out an opening for this switch to fit into and put it back on the console. It looks clean now, OEM looking. I know the post is worthless without pics, but when I find a digicam, I'll get a pic up. Has anyone done the same thing? Just wondering.
Old Mar 9, 2003 | 03:01 PM
aux's Avatar
aux
More Black on Black Crime
my alarm LED is where the switch should go. h:. id like fogs some day. h:
Old Mar 9, 2003 | 03:06 PM
BlackChrome's Avatar
BlackChrome
E46/CD5
So you mean you cut a hole on that blank panel to mount the fog light switch? I thought everyone does it that way? Mine is like that (with the alarm LED) and now I am going to wire it up with the OE factory foglight switch, which mounts at the same spot. The wiring is going to be a pain in the butt!
Old Mar 9, 2003 | 03:39 PM
RY2K's Avatar
RY2K
5 speed
i wanna do that but not sure how
Old Mar 9, 2003 | 05:37 PM
bruce_91zx's Avatar
bruce_91zx
engiNERD
RY2k: well the fogs I bought came with a mounting bracket which the switch fits into. Instead of using it, I cut the same sized slot in the blank panel with a soldering iron and used that(I think a dremel would be better, but this turned out good too), then routed the wire to the switch. There are spots in your firewall which run other wires into the car, use those places to get the foglight wires into.
Blackchrome: yep. well i didn't know thats common b/c I've seen others use the mounting bracket that comes with the fogs which are fugly IMO.
But on a bad note, my eurolite low beam bulb blew today, I would go with another brand but I still have the eurolite highs and they also match my polarg corners. only had for 8-9 months. =( time for 9005 conversion I guess.
Old Mar 9, 2003 | 05:53 PM
DEaccord95's Avatar
DEaccord95
Living The Import Life
yeah my alarm LED is in that space now....and my strobe lights switch is by that piece near the ignition
Old Mar 9, 2003 | 06:00 PM
KMFDM's Avatar
KMFDM
:wopics:
Old Mar 9, 2003 | 06:10 PM
bruce_91zx's Avatar
bruce_91zx
engiNERD
Originally posted by KMFDM
:wopics:
:werd:
Old Mar 10, 2003 | 08:05 AM
dantastic's Avatar
dantastic
cx power!
oem switch 0wn3s j00!
Old Mar 10, 2003 | 02:48 PM
bruce_91zx's Avatar
bruce_91zx
engiNERD
very nice. =)
