Fuel Pump??
Old Feb 20, 2003 | 07:51 AM
NathanS's Avatar
NathanS
Default Fuel Pump??
This to is my first car and its already being a pain. I'm not sure whats wrong with it. I was driving it along and the RMPs dropped quickly, and the car shut-off. 5 mins. later the car started right back up again. I got it home, it seems to me if i got it up past 3500 RPMS it would shut-off. We replaced the fuel filter and now it won't start up. Could it just be ice in the line or bad gas??? I'm open for suggestions.
Old Feb 20, 2003 | 08:18 AM
AcuraFanatic's Avatar
AcuraFanatic
First off, what year Accord? It doesn't sound like bad gas, it would have effected all RPM ranges, although it would be more prominent in higher RPM's. You would probably notice detonation before the car shutoff.
My best guess is yours - the fuel pump committed suicide.
Old Feb 20, 2003 | 08:30 AM
NathanS's Avatar
NathanS
its a 91, and yeah i did
Old Feb 20, 2003 | 09:58 AM
Sham's Avatar
Sham
Did you do a tune up after buying it? This is something that is suggested, since you'd be starting from "new" with the basics of the car. So if something does go wrong, like in your case, you can rule out the things you replaced.
BTW, I don't feel I'm getting the best milage out of my accord, how would someone go about replacing a fuel pump? Is it expensive?
Old Feb 20, 2003 | 11:53 AM
b12uceHuy's Avatar
b12uceHuy
Jizz Maste12
It could be a number of things tainted gas, fuel pump, sensors, bad ECU, & eletrical stuff plugs etc...
Old Feb 20, 2003 | 03:34 PM
bonestock's Avatar
bonestock
go for a walbro 255lph fuel pump
Old Feb 21, 2003 | 06:22 AM
NathanS's Avatar
NathanS
Default I'm pretty sure it's not the fuel pump now
Here's the latest on the problem...
The car started cold and ran fine until it warmed up to normal operating temp, then it just stopped, as if I'd turned the key off.
When we disconnected the temp sending unit (the two wire connection, not the one wire that feeds the temp guage), we could get it to keep running. Are we talking about a bad sensor or computer, or something else?
Old Feb 21, 2003 | 10:01 AM
immalooser's Avatar
immalooser
if he's on a stock fuel system that will be too much flow. If your not going hardcore performance just get a factory fuel pump.
