94 Accord will not start, d4 flashes multiple codes
Old Sep 9, 2009 | 03:14 AM
Charlz B.'s Avatar
Charlz B.
Default 94 Accord will not start, d4 flashes multiple codes
G'day all! I have a 94 LX that quit starting not too long ago. I have been through the normal things...fuel pump, fuel pump relay...with no luck. As I am finding things, the fuel pump will not run with the relay plugged in (tried a couple different ones) but it will if you jump the wiring harness with a paper clip, however the car still will not run. Further, after trying to crank the vehicle, the d4 light will come on so naturally, I checked for codes and got codes 1, 8, 13, & 14....out of the blue! I don't know if the transmission codes will keep the fuel pump from operating or not, so I need some insight from someone who's been through this a few times.
All help is appreciated and thanks in advance. :beer:
Old Sep 12, 2009 | 07:53 AM
cruzalekz's Avatar
cruzalekz
so problem is vehicle cranks but no start?
tranny problem should not get in the way for the motor to start not unless theres a problem with your shifter positioning
Old Sep 12, 2009 | 05:05 PM
Cole87's Avatar
Cole87
Happened to someone else on another forum. He tried a bunch of shit none of it worked ended up ordering a new ECU.
Old Sep 13, 2009 | 03:03 PM
Charlz B.'s Avatar
Charlz B.
Yep, the car will crank until the battery is drained but it will not catch. I'm thinking it has to be a broken electrical wire or a bad ECU. I found a flowchart in the accord manual I'll go through when I get an extra set of hands. Thanks for the thoughts...I'll post results if and when I solve it.
Old Sep 19, 2009 | 12:31 PM
cruzalekz's Avatar
cruzalekz
now car cranks right,
forget the flow chart for now,,, check basics. do u have spark?
do u hear your fuel pump when you turn the key to "on" position?
