help engine code 76
Old Jan 14, 2003 | 08:25 AM
RKV's Avatar
RKV
hey, go get the codes pulled, and talk to Jweller from hondasociety man. i think HS is down right now, so just wait. dont waste your $$ on stuff u dont need. my advice, i spent $350 cuz i took it to a mechanic who just guessed the DAMN problem, wanted to kill him cuz he said he's sure he was right each time he fixed something. first he said, it was the o2 sensor on the header, than the ignition something. always wrong. so, just wait. no need to guess, cuz u can get it right if u can talk to som1 who knows the codes well.
Old Jan 14, 2003 | 09:04 AM
v4lu3s's Avatar
v4lu3s
your accord is a v6 right?
Old Jan 14, 2003 | 11:12 AM
Accordz's Avatar
Accordz
The board is not down, just the main page, hopefully you have links so some of the forums.
Old Jan 14, 2003 | 11:59 AM
RKV's Avatar
RKV
thxs man, i will try to see if i can get on the HS board..
Old Jan 15, 2003 | 04:38 AM
PeachBoy's Avatar
PeachBoy
v4lu3s i have an i4...and i havent picked up the o2 sensor yet...im going to hook it up to my friends snap on computer (at his work) and test my converter efficency...the graph should tell me if its just my converter and how poor it really is...man this is such a pain
Old Jan 15, 2003 | 04:46 AM
v4lu3s's Avatar
v4lu3s
weird cause last i knew 76 was a v6 only code...
the desctiption of it is:
Cylinder 6 Misfire or a Random Misfire
a condition is present that is creating a cylinder misfire
* valid code for V-6 engine only
Old Jan 15, 2003 | 04:53 AM
PeachBoy's Avatar
PeachBoy
hmmm...in my haynes it leaves out that v-6 part and says obdII...
Old Jan 17, 2003 | 04:40 AM
PeachBoy's Avatar
PeachBoy
my friggen high flow cat is not efficient...anyone else have this problem with performance cats? frig...
Old Jan 17, 2003 | 05:10 AM
v4lu3s's Avatar
v4lu3s
what kind of high flow cat is it?
Old Jan 17, 2003 | 11:48 AM
RKV's Avatar
RKV
i almost bought a high flow cat from random tech, and the guy who was the tech guy told me, the cat is only as good as the install. where did u install the high flow cat, and what brand is it btw? sorry if u stated it already, im too lazy to scroll down and check. cuz maybe it was installed poorly? many times when its not a direct fitted one, cuz many are universals, such as carsound. and u need to weld and cut, thus, sometimes they go bad easier if installed incorrectly or poorly.
