Need help with Lights
Old Feb 20, 2009 | 10:43 AM
footballstar09's Avatar
footballstar09
Default Need help with Lights
Can any one tell me the best way to change out head and tail lights in a 2000 Honda accord 4dr 4cyl. Anything will help.
Old Feb 21, 2009 | 09:51 AM
cruzalekz's Avatar
cruzalekz
it should be an easy bolt on type work. take out grommets that holds the carpet and the light bolts should be exposed already
Old Mar 4, 2009 | 10:31 AM
94jdmcivic's Avatar
94jdmcivic
you will have to remove the front bumper for the headlights. What kind of head and tailights are u putting in?
Old Mar 6, 2009 | 10:10 PM
Neubie's Avatar
Neubie
^^^thay haven't changed that yet!!!! don't get me wrong, i love my honda's......but that design for the headlights is straight up...ARG:angry:
The tail light nut's should be like an 8 mm, that'll be a walk in the park compared to the headlight's lol
Old Mar 7, 2009 | 02:05 AM
A-series's Avatar
A-series
v-card member alpha
Bulbs is one things, the entire assembly is another. I've never worked on that year Accord, but I'd assume the above suggestion is correct for replacing a taillight assembly. For the bulbs you just need to remove the inner cover, self-explanatory when you get a look at it.
On some models (can't say for sure this applies to '00 Accords), ones on which people often suggest removing the bumper to replace headlight/front corner lamp bulbs, you actually only need to pull back the front fender-liner, it's even easier and faster than removing the bumper.
If you're replacing the entire headlight assembly, you should be able to figure it out by take a good, close look and determining which bolts need removed, etc.
If it's just the bulbs, the procedure is simple and is listed in the owner's manual.
Old Mar 7, 2009 | 08:43 PM
Neubie's Avatar
Neubie
^^^lol i'd hope he's only changing out the bulb's..I can speak from experience, that on my 5th gen......it is a pain removing the actuall assembly.....unless you'r gonna cut off the outside headlight mounting bracket......that bumper HAS to come off........i pray for you that honda changed that on the six gen!
