Help. Another problem with Indiglo guages
Old Jan 7, 2003 | 08:19 AM
qwho387's Avatar
qwho387
Default Help. Another problem with Indiglo guages
I just installed my guages on my 1990 honda accord and They are not functioning quite right. Sometimes when I turn the car over they do not turn on and other times they do but i cannot adjust the intinsity. But whenever i just turn on the electrical system without starting the car they work fine. wierd?
I tried wireing the guages into a few adjacent power sources with no luck so i just spliced the power going to my stereo and they worked. Should I re-wire them back to the fuse box or something?
Thanks for any help you could offer.
Old Jan 8, 2003 | 06:44 AM
bacal36's Avatar
bacal36
Default Re: Help. Another problem with Indiglo guages
Did you follow the instructions?
I hooked mine up to the wires coming from the dash light dimmer. (left hand side w/ the knob) It was easy. My gauges came w/ 2 wires. I just spliced those and they work fine. No problems what so ever!
Old Jan 8, 2003 | 04:05 PM
qwho387's Avatar
qwho387
I followed the instructions but they did not seem to work on the dimmer switch. The transformer that it came with makes a buzing noise so maby its bad. I might return it.
Old Jan 9, 2003 | 04:59 AM
bacal36's Avatar
bacal36
Yeah that sounds like a good idea to do... because it should work when you hook it up to the dimmer switch...
Old Jan 9, 2003 | 05:17 PM
qwho387's Avatar
qwho387
hopefully I can just return the box. Getting that out will be easy but I dont want to take the guages out.
Old Jan 9, 2003 | 07:47 PM
Phat8186's Avatar
Phat8186
I have probs with my reverse indiglo gauges in my 5th Gen accord. I hooked them up to my dimmer switch and i can adjust them and everything but sometimes they just seem to flicker like hell i dont know whats weong with them. could the transformmer possible be bad if so is there anyway that i can get that at radio shack or something or I would have to get a whole new set of reverse indiglo gauges.
