No climate control when remote starting 2004 Honda Accord
Old Jan 8, 2009 | 12:45 AM
degarciajr's Avatar
degarciajr
Default No climate control when remote starting 2004 Honda Accord
Hello,
I recently installed an Autopage RS-1000 remote start/alarm system in a 2004 Honda Accord. I used a transponder bypass module for this installation. Car remote starts fine but I am not able to turn on the dual climate control. The stereo and navigation system work fine when car is remote started. I confirmed I have power (in remote start) to both ACC1, ACC, and IGN1. Does the climate control system receive power from another source other than ACC1, ACC2 or IGN1? Climate control works fine when car started with key or key just turned to the run position.
Old Jan 10, 2009 | 04:37 PM
Tedmond's Avatar
Tedmond
the only way your climate control will not go on is because your ignition is not getting power. You might verify that you have power but i install on many cars and without 12v on the ignition, climate ocntrol will not work. Check out the12volt.com, i have the same user name and if you ask a question in the forum, it will be answered there fast. Im a reconised member.
