specialty products alignment kit ???
Old Dec 2, 2002 | 09:49 AM
92 wagon's Avatar
92 wagon
Default specialty products alignment kit ???
hello, all, i have been looking at the specialty products alignment kits for a 92 accord and was wonderin which ones i should go with. should i go with the sliding/adjustable ball joint kit or should i go with the upright anchor bolt kit. i was just lookin at nopi.com incase i did nto explain it right, but any suggestions would be appreciated
Old Dec 2, 2002 | 09:52 AM
b18cya's Avatar
b18cya
uh, no u suck
SPC makes very good kits
the ball joint will be cheaper to install, but not by much. & the ball joint kits are easier for the alignment guys to adjust
Old Dec 2, 2002 | 10:03 AM
92 wagon's Avatar
92 wagon
but which will be better as far as not rubbing the inner fender when adjusted? i have read of the ingalls kits and some kits rubbin after install
Old Dec 2, 2002 | 10:13 AM
v4lu3s's Avatar
v4lu3s
thats going to happen no matter what kit you get.
all kits basically move the ball joint/control arm out further to compensate for camber. onc eyou correct abotu 1.25 degrees, you are at risk for fender to control arm contact.
Old Dec 2, 2002 | 11:48 AM
brads94accord's Avatar
brads94accord
i have the specialty products front ball joint kit on my 94 accord, i have the kit adjusted all the way out because im lowered to a one finger gap on 16's. it rubbed a little when i first lowered it so i had to use a dremel and cut out the plastic in the fender. what was weird is that on one side it cleared it by like 1mm, and on the other side it would bang/rub. i had to put my weight on the fender to pop it down into place whenever i would lower it off the jacks. over time it eventually wore a little dent or something in there and it doesn't bang anymore.
