Fuel Pump Help
Old Jun 18, 2008 | 07:48 AM
hnkenstine's Avatar
hnkenstine
Default Fuel Pump Help
93 accord fuel pump wont kick on replaced fuel pump and relay still nothing PLEASE HELP
Old Jun 18, 2008 | 10:39 AM
JimBlake's Avatar
JimBlake
Did you check for broken wires before buying parts?
Old Jun 18, 2008 | 11:48 AM
IkeRay's Avatar
IkeRay
Aka #5
by relay, do you mean MAIN relay, or just the under hood relay to the fuel pump??
99% of the time, when the fuel pump doesnt kick on, on a honda, AND its summer, its main relay. to diagnose, turn key to on (but dont start) and listen for the fuel pump to click on the same time are the CEL clicks off. if you don't hear a click, then main relay is bad. try tapping (/kicking) the lower panel just above the fuse panel door on the driver side foot well (your left foot) and cranking and see if the car starts.
Old Jun 18, 2008 | 08:54 PM
hnkenstine's Avatar
hnkenstine
the main relay is what i replaced and the car was running and then just shut off so i dont think the wires would have broke and i didnt smell anything burning or hot i checked all the fueses and the pump dosnt kick on it doesnt make any noise and there is no fuel pressure i thank you guys so much for your help if you can think of anything ill try it at this point
Old Jun 18, 2008 | 09:19 PM
IkeRay's Avatar
IkeRay
Aka #5
oh, alright, most people don't suspect the main relay...good to know thats what you had replaced.
hmm, to have it randomly shut off IS odd...
Old Jun 19, 2008 | 06:52 AM
hnkenstine's Avatar
hnkenstine
do you know if the ecu runs the fuel pump in that year
Old Jun 19, 2008 | 07:18 AM
IkeRay's Avatar
IkeRay
Aka #5
have you gone through the FSM or haynes? they usually have a troubleshoot diagnosis tree. if you don't have one, you can get it online here but I have never downloaded this one so I couldn't be 100% on the legality/quality.
Old Jun 19, 2008 | 08:21 AM
JimBlake's Avatar
JimBlake
The main relay switches the pump on & off, but the ECU tells the main relay what to do.
You can check for power back at the fuel pump wires. If there's power back there, then the pump is bad. But it's a new pump so I bet you'll find there's no power back there.
Probably I would start by checking power & ground at the main relay. I don't have a circuit drawing for 93 but that would be real good for you to have. What's your electrical troubleshooting experience/skills?
