91 accord power window motor replacement
Old Jun 1, 2008 | 04:41 PM
mlphipps03's Avatar
mlphipps03
Default 91 accord power window motor replacement
i have a 91 honda accord coupe, it has power windows and wont roll up, we ran alot of tests and found it was the motor for the window, i have tried to remove the motor i can take out all the bolts but the motor wont come out. After hours of trying to get the window up We were able to pull it up 3 inches. Not good enought. i live in Oregon where it rains alot and need my window up anyone got any suggestions to get the window up or how to replace the motor without having to pay honda $400 PLEASE I NEED HELP ASAP!! thank you to anyone who can help me!
Old Jun 4, 2008 | 08:55 PM
Rilox08's Avatar
Rilox08
Here is something to help you out:
http://www.hondahookup.com/manuals/
Download the 91 accord service manual, chapter 14-12 has the window stuff, not sure where the other chapters are??
Not sure if you tried it since the description didn't mention, but try getting window up by having the car on. Push up on the window controls, and have someone pull it up at the same time. Possibly give the gear mechanism and "rail guides" (will call them that?) a spray of wd40 to maybe loosen it up a bit.
Once the window is taken up far enough there is a certain point where you are able to access the bolts easily in order to separate the glass window from the motor. Make sure you don't drop it or anything, also when you get it apart don't leave it in the sun, much less take it inside in the cold too quickly.
Again using the motor, try and maneuver the pieces so they are the most condensed. Remove a few bolts, and it should slip out. Of course install is reverse.
You may wanna buy new weatherstripping since this is the easiest time to replace it. FYI: motor and all the goodies run about 100
Hope it helps
