90 Accord front speaker removal
Old May 12, 2008 | 12:58 PM
snowcrashed's Avatar
snowcrashed
Default 90 Accord front speaker removal
Wanted to throw some alpines i had laying around in the Accord but im not sure how to go about this, do those big ugly speaker covers come off separate or does the whole door panel have to come off?
Old May 12, 2008 | 01:22 PM
Cousin It's Avatar
Cousin It
I have a 91 and the speaker covers come off separately.
Old May 15, 2008 | 12:18 PM
wingzero210's Avatar
wingzero210
ur going to have to take off the whole door panel
Open plastic screw cap inside door handle area using small thin screwdriver and remove screw. The cap swings from the narrow hinged side. It is easy to break. Slide handle assembly forward to release hooks. Lift out from panel slightly and release clip on linkage rod with small screwdriver. Unplug switch from assembly.
Remove plug from inside armrest cup and remove screw.
Look for plug covering screw below armrest and toward outer edge of door. Remove.
Grab lower edge of panel near speaker grill and pull outward. Continue working toward outer edge, pulling lower edge of panel.
When bottom is free, work up both sides unsnapping clips.
When all clips are loose, lift up on the panel to remove from top track.
You will need to unplug the window switches and the door light.
Old May 16, 2008 | 05:42 AM
snowcrashed
Beautiful! I think im going to order some replacement door handles and fix that while im at it if they already need to come off.
