who's changed their timing belt?
Old Nov 5, 2002 | 01:22 PM
JiggaFan's Avatar
JiggaFan
PIMP-strollin' on 'em!
Default who's changed their timing belt?
I have a '97 EX with the VTEC 2.2L engine. Is it possible to change the timing belt in my buddy's garage? He's got every tool in the book including a cherry picker thing or whatever.
Dealer wanted $300 to do it at the 105k checkup. I'm now at 158k mile--and of course i didn't pay the dealer to do it back then.
So is it doable. Anything to watch out for. Any tricks or shotcuts to leave more time for beer drinking?
Old Nov 5, 2002 | 01:44 PM
dantastic's Avatar
dantastic
cx power!
its doable, but its a major pain. if youve never done it before, prepare to spend a whole day on it.
i bought a new belt (timing and balancing) water pump, cam gear, and pullies. i had my mechanic install all of it for $150.
Old Nov 5, 2002 | 01:55 PM
when they install the belt, it's more than just swapping parts. the dealer uses a laser to calibrate the engine timing.
Old Nov 5, 2002 | 02:08 PM
jschmid's Avatar
jschmid
Default Re: who's changed their timing belt?
Woah...no ghetto talk. Much better.
Okay, I'm done giving you sh*t about that...I'll shut up now.
It's just so much easier to read...
Old Nov 5, 2002 | 02:59 PM
dantastic's Avatar
dantastic
cx power!
i have the same laser. its called a timing light
Old Nov 5, 2002 | 04:40 PM
VRGNCD5's Avatar
VRGNCD5
cause it's tight!
:doh:
Old Nov 6, 2002 | 05:25 AM
Rycechyk's Avatar
Rycechyk
Default Re: Re: who's changed their timing belt?
Oh man, you beat me to it. I wanted to say it first, but you kind of deserved the privilege
Old Nov 6, 2002 | 11:56 AM
David Helper's Avatar
David Helper
if you install the timing belt and line up your timiming marks(which you should do before removal) set the tension correctly (carefull) you dont need a timing light
Old Nov 6, 2002 | 12:33 PM
JiggaFan's Avatar
JiggaFan
yeah, ma pops did it to an older Ac Legend. He said something about "it can't be done wrong". I dunno. Are there some grooves in the belt or something that have to be lined up in order for the new belt to fit back on.
Oh, do you get any better performace (of any sort) with a new timing belt. Or more specifically, have I lost performance by letting the old timing belt stay on so long?
Old Nov 6, 2002 | 01:08 PM
RY2K's Avatar
RY2K
5 speed
how often does the timing belt need to be changed?
and in the Accord is it an actual belt or a chain?
