Aftermarket Steering Wheel Horn Problem
i recently installed a momo steering wheel but i cannot seem to get the horn to work. i wired as the diagram showed by it doesn't make sense because it doesn't connect to the wire coming from the steering column, plus there was no connector that adapted to the wires coming from the steering column. anyone have any experience with this?
there is a reel that allows the steering wheel to move freely. If you wish to do the horn, you must run a wire down to gyour kick panel and tap into the horn wire. what year is this accord.
most honda's are LIGHT GREEN/BLUE @ ignition harness
