location of pcv valve and ERG
I can't see (find) the pcv or erg on my 2000 3.2tl and my 2004 Civic. I've worked on cars for a long time and never had a problem.
The EGR system on the TL is a series of passages through the intake manifold. If you remove the top plate on top of the manifold youll find the labyrinth area that often gets clogged. Follow the ports downward(removing parts of the intake a piece at a time to clean the entire system.
IIRC the PCV valve is installed in the rear valve cover pushed into a rubber grommet almost like an old school valve cover breather.
k.
k.
