'02 Timing Belt Question
Old Feb 28, 2008 | 11:36 AM
sbalgach's Avatar
sbalgach
Default '02 Timing Belt Question
Hi
'02 Accord 4 cyl.
How hard is the timing belt to change?
Can anyone please post instructions or special tools needed?
Thanks,
Steve
Old Feb 28, 2008 | 11:38 AM
Line7's Avatar
Line7
Platinum Member
You'll need the manual...No less.
Old Feb 29, 2008 | 05:14 AM
flyromeo3's Avatar
flyromeo3
when I had my timing belt changed I over looked the mechanic's shoulder ( he didnt mind cause I asked if i can look over his shoulder while he does the work so I can see/ learn ) but I recommend having someone do it for you.
The bolt on the crankshaft was beyond a bitch to remove. They needed to put a torch to the bolt and once it was super hot they used air tools to remove it.
After that bolt was removed everything else seemed pretty easy to take off.
If you dont have the tools I definitely would have a shop do it. It just takes one mess up to bend a valve if the cam isnt adjusted properly.
Old Mar 5, 2008 | 08:06 AM
anhqle's Avatar
anhqle
You need to order this from "TheToolWarehouse.net"
Schley Products 60100A
Honda and Acura Long 4" Offset Damper Pulley Holding Tool
Order# SP 60100A SP 60100A $38.95 $38.95
You need it to remove the pulley from the engine, I could not remove mine with a 3/4 airtool.
Anh Le
Old Mar 5, 2008 | 08:58 AM
flyromeo3's Avatar
flyromeo3
http://www.thetoolwarehouse.net/sear...oreid=toolswai
nice find Anh
