trunk light in 1990 accord
Old Jan 23, 2008 | 02:01 PM
wingzero210's Avatar
wingzero210
Default trunk light in 1990 accord
How do you take out the whole yellow piece holding the tiny light, i want to put in this neon bar.
Old Jan 23, 2008 | 04:30 PM
Tedmond's Avatar
Tedmond
no need to pop he whole thing housing out, just take the plug out and tap the power from that for your neon lights.
Old Jan 26, 2008 | 02:19 PM
wingzero210
wheres the plug and wats it look like
Old Jan 26, 2008 | 09:20 PM
Tedmond's Avatar
Tedmond
at the trunk lock there will be a black connector. one black and one red wire. The red is constant and the black is only triggered when the trunk is open. Or you can pop the clear cover off the light, pull the bulb out, using a flat head slowly pry the silver reflector out and get access to the wires there.
Old Jan 27, 2008 | 01:08 PM
wingzero210
ok thanks it works i just took out the housing
Old Jan 27, 2008 | 04:28 PM
Tedmond's Avatar
Tedmond
hey dont forget to use a relay to tun on the neons. they might draw more than what that wire can give.
Old Jan 28, 2008 | 12:19 PM
wingzero210
ok ill pick one up at pep boys
