98 Accord - can't compress rear brake cylinder
I replaced the rear wheel bearing in my 98 Accord which has disk brakes but had a bear of a time getting the caliper off the disk since there was a rusty ridge on the outermost edge. Tried to compress the brake cylinder but couldn't and now can't get the caliper back on. Is there a locking mechanism in the hydraulics or does the parking brake have a lock that prevents my compressing the cylinder? Decided to leave problem out in the driveway till tomorrow am.
Hey, you know the cylinder is cut away in the form of an X which could be designed to facilitate turning it in ... tomorrow I'll give it a try ... thanks for the prompt responses.
lots and lots of fail
1 Post
Or use a large prybar/crowbar/screwdriver...there are a ton of threads about this. you better pray you didn't damage the piston by trying to compress it, I know a lot of people who have.
Shows to go, don't work on your car without the cheap insurance of a $50 service manual for tricks you might not know about no matter how familiar you are with mechanics...
