Engine Coolant Question...
Old Oct 18, 2002 | 07:04 PM
REbornHONDAneer's Avatar
REbornHONDAneer
Honda Biased
Originally posted by Jeff TYPE R
as long as u has something swishin arounds its all good. use water if ure cheap. whateva yo
water boils at a temp FAR below than the actual temp the car reaches. It also freezes far above the low's in the northern states. DO NOT USE WATER!
Like Blackmajic said, "radiator's arent cheap". Unless u like replacing them :-)
Dave
P.S. Also make sure ur fluid is not pure antifreeze. 50/50 or i choose 30/70 to be safe.
Old Oct 19, 2002 | 04:58 AM
Mr Hyde's Avatar
Mr Hyde
Accord Forum Moderator
Originally posted by /^Blackmagik^\
whatever.... coolant is coolant.
No its not, that being said, you also dont have to use Honda coolant, but you must use coolants which are borate and silicate free which are usually the extended life coolants. Anything else can cause wear on the seals and waterpump., and eventually leak. Prestone extended life which is orange is a good example of something that is perfectly fine to use.
Just call me.............Mr Hyde
03 Topaz Blue 540i M-Sport
The TL-S / The 540i
Old Oct 19, 2002 | 07:17 AM
REbornHONDAneer
Honda Biased
hhmm...how important is this really? If u use the wrong coolant but change at intervals less than "recommended", will it be fine?
The properties that the coolant must have are actually harmful elemets that harm our seals removed? Why are they there if they harm seals? Or do they JUST harm Honda's seals? Basically what i'm getting at is why would a company put out a coolant that harms engines.
Thanx!
Dave
Old Oct 19, 2002 | 07:31 AM
Mr Hyde's Avatar
Mr Hyde
Thanx!
Dave
Well its not that the coolant is harmful to all makes, its just that they are not as friendly to Honda cooling systems and Im sure other newer cars as well in particular. There are TSB's out regrading the use of noncompatible coolants in Hondas. Just like the power steering and now tranny fluid recommendations made by Honda, they also have recommendations for the coolant.
You can use whatever you wish, but the coolants I talked about are the ones recommended in our cars for maximum life of the seals and waterpump. Not using them can also explain why the original poster notices increased coolant usage. I noticed the same on my Accord. A switch to the extended life solved that problem.
Old Oct 19, 2002 | 07:56 AM
REbornHONDAneer
Honda Biased
Ok, what did u mean by "poster" in the last paragraph there? Increased coolant usage? What exactly does that mean, do u mean the engine is leakin coolant and blowing seals leading to increased coolant usage? J/W
So u recommend Prestone Ext. Life right?
Thanx
Dave
Old Oct 19, 2002 | 07:57 AM
JDM Spec R's Avatar
JDM Spec R
Honda uses these additives in their coolant, PS fluid, and trans fluid, that other chemicals dont have. If you use the non honda stuff you do risk messing up seals and such. We see that at my dealership often.
Old Oct 19, 2002 | 10:07 AM
Mr Hyde's Avatar
Mr Hyde
Thanx
Dave
Poster as is person who wrote the original post dude.
An increased coolant usage means just that. Whether its increased use, seepage, whatever it may be.
Old Oct 19, 2002 | 02:09 PM
REbornHONDAneer
Honda Biased
oh I thought u meant somethin else.....didnt think the "poster"
but i see what u mean. Thanx!
Dave
Old Oct 19, 2002 | 10:17 PM
Jeff TYPE R's Avatar
Jeff TYPE R
Crazy AE86 dude.
Dave
oh ok, and what temp does water boil at? i hope u dont plan on saying 100degrees..cuz thats ****en wrong. hte pressure in your coolant system is way higher than 1atm, so the bp of water is much higher.
Old Oct 20, 2002 | 05:49 AM
REbornHONDAneer
Honda Biased
ok..first i didnt say what temp water boils at cuz i didnt know in degrees. I wasnt gonna stick my foot in my mouth. But i'm pretty sure that our cars go beyond boiling point for regular tap water.
what is "1atm"? also what is "bp of water"? please alaborate or your post or it is useless to people who dont know what that means.
Dave
