no check engine or any other lights
Old Nov 22, 2007 | 03:51 PM
dabaddon's Avatar
dabaddon
Default no check engine or any other lights
ive just replaced the clutch disk n now stumbled onto more problems. when i try to start my car, it just ticks n sounds like its coming from the radio. also when i turn it to the on position, no engine or warning lights popup other than the brake warning light.
i replaced the main relay fuse under the dash, found the ecu code to 6 flashes which is "COOLANT TEMPERTURE." idk how to resolve this, i hate to just junk it even tho i got for like $300 also put alot time in it, car was running great previously when i bought it and why it was cheap cuz of the worn clutch. any help would b appreciated.
Old Nov 23, 2007 | 07:50 AM
nspec_Cd5's Avatar
nspec_Cd5
u sure all the wires in the engine bay are still connected? correctly? around the area u worked.
and which model is this? year, trim?
Old Nov 25, 2007 | 08:06 AM
dabaddon's Avatar
dabaddon
its a 88 accord lxi 2dr, i got a couple days left b4 my ppls get rid of it
i have plugged up everthing i took apart back to the way it was, will dbl check tho, its gotta b an electrical problem
