help with shift light install...92 accord ex
Old Nov 17, 2007 | 02:23 AM
92accordh's Avatar
92accordh
Default help with shift light install...92 accord ex
alright so i have searched all over for help with this. i understand the basics and that this is very simple, however i am not good with wiring diagrams nor do i have a clue what im lookin in a wiring harness.
i have a 92 accord as stated above what would be a good 12v to tap into and how would i go about doing it? also if anyone could provide pics with there install i would greatly appreciate it! also what wire would the green one off the shift light go into on h22 dizzy? thanks,92h
Old Nov 17, 2007 | 10:18 PM
nspec_Cd5's Avatar
nspec_Cd5
it'll be the white wire comin out of ur iginition harness (i'm pretty sure its white)
to find out which wire it is, plug a tester in to each wire and the one that gets 12 volts when the key is in "on" position, is the one u need to use.
how many wires coming out of the shift light?
i think the green is for ur tach, it'll go to the one of the wires coming out of ur distributor. there's a plug w/ two wire coming out of it (forgot what color they're), but its one of them and u can test around w/ each one. it wont hurt the system. (plug in the green/tach wire to each one to test and see if the tach on the shift light works, ur motor will have to be running)
