battery wont hold charge...
Old Sep 20, 2007 | 06:14 PM
sjl2484's Avatar
sjl2484
Default battery wont hold charge...
I was driving the other day and my car started to act up and then it died while i was driving. I replaced the battery and the altenator and the battery wont hold a charge and the new alt was only putting out 12.5 volts. Went back to autozone and swapped altenator and my battery still wont hold charge and alt not putting out proper voltage. had new alt tested before i installed it and it was good. Anyone with any ideas. Honda said it is possibly a wiring issue...
Old Sep 20, 2007 | 07:15 PM
HanmeSAL's Avatar
HanmeSAL
check your belts also.
Old Sep 21, 2007 | 03:09 PM
sjl2484's Avatar
sjl2484
belts are only a couple of months old. still in good shape
Old Sep 21, 2007 | 06:14 PM
HanmeSAL's Avatar
HanmeSAL
how old is your vehicle?
If you have voltmeter, check the voltage on the battery and start the car.
it should jump up to around 13.5v. If it's not, it's not charging. Or if not, it could just be corrosion on connection.
take it to autoshop, would help a lot if someone actually take a look under the hood.
Old Sep 21, 2007 | 08:09 PM
v6_accord_jerz's Avatar
v6_accord_jerz
Stupid Power Ball
Could be due to a faulty alternator. Have it checked.
Old Sep 21, 2007 | 08:52 PM
sjl2484's Avatar
sjl2484
i have put two altenators in it....the altenator now tested good before i put it in...i think it is a wiring issue because the altenator is not putting out...
Old Sep 24, 2007 | 12:55 PM
sjl2484's Avatar
sjl2484
found the problem....was a 15 amp ecu fuse...hope that works...
Old Sep 24, 2007 | 01:24 PM
tatvamasi_12's Avatar
tatvamasi_12
Hey man, see the belt tension. if you keep it loose or keep it too tight these kind of things happen.
